1 - 5 of 5 Posts
When I am trying to navigate the menu on multiplayer tofind server, edit classes, view player stats, ect. it freezes for about 10 seconds every time I click something.
It also disconects and wont load the server list every other time I want to find a game to play forcing me to close and re-start the game just to load the servers (it's not my filter options).
I know my bro has the same problem with his PC and its a different build than mine with a different OS.
Is there any way to fix this? It's so anoying I can barely stand playing it anymore.
The PC im using is my sig rig.
· Premium Member
This is just me being unhelpful, but I believe you meant to use "(well)"
Try deleting your config file and letting the game create a new one on its own... it could be an issue with a setting interfering with a patch. I had issues when one of the original patches installed because it reduced the max AA from 16X to 8X... my config was set to 16X so I was have major game issues.
Another thing to do is to verify your game files via Steam, and also make sure that you have all the latest video drivers installed.
Deleting config_mp and config fixed the problem. +rep
1 - 5 of 5 Posts
