So today while overclocking an amd athlon xp 2500+, I had set the frequency to 200 (MHz i think [first OC ever]) and put the voltage to +10%. the system was running fine but about a third of the way through the wPrime stress test it gave me the BSOD. earlier i had it at lower voltages and it would BSOD earlier so i had just increased the voltage to get more stability but +10% was the max voltage the bios would let me have. So i went back into the frequency and lowered it to 195 and then memory clock opened up so i decided to raise it by the lowest value possible (25% i think). so i saved and then when i looked back at the screen 1 min later it was just black with nothing on it. monitor had gone to sleep. couldnt wake it with mouse or keyboard so i turned the pc off and back on and it never showed anything. monitor woke but then went back to sleep straight away. so what do you think is dead if anything. the memory?
