1 - 14 of 14 Posts
Im having problems with my blackjack 2. I got my phone over ebay and it works perfectly fine, the only problem is that i am having problems settign up with my phone with activesync. I dont have the software cd that would have come with the phone had I bought it from a store. What do I need to do to get my phone to sync with my computer so that I can get windows mobile updates?
I think the problem is that even when plugged in my phone isnt recognized, it still charges, but just wont recognize that its plugged in
I remember that happening when I didn't have the correct stuff from Windows downloaded. Do you have the most recent version of ActiveSync?
Have you tried connecting with the cable and manually using the activesync under the start menu on the phone? When you select activesync you can go to menu and settings to make sure the "when cradled" is checked.
the problem is that on activesync on my phone it is telling me i need the getting started software on the cd they give you, but i dont have that cd. Shouldnt it automatically detect my phone?
Discussion Starter · #12 ·
I talked to the samsung support and apparently i have the wrong cable, is it true that there are just usb cables that only charge and wont sync? do i need a legit samsung cable for it to sync?
1 - 14 of 14 Posts
