The window is attached using a very simple method really I measured equal distances apart and then drilled 4 small holes.
I used motherboard mounting nuts and attached them to these 4 holes.
I then measured the exact same equal distances on the side panel and cut 4 holes as well.
I then used some cut down thumb screws and it was done.
I finished the window by putting some black backing alond the edges.
