I bought this for $95 at a shop.
The switch, can someone identify them? -> I think they are a replica of MX black? I could be wrong though.
EDIT: Switch is "Greetech GT02A1ADW "
EDIT2: Driver for keyboard is released by manufacturer, refer to: this post
The instruction booklet says you can
-Switch from 1000hz polling to 125hz (1ms/18ms)
-Change lighting effect
-Activate turbo key/autopress
-How to remove keys / install rubber ring
-Mode to disable window key "game mode"
There are 20x rubber o ring included, the intended purpose is to reduce the typing sound from the keyboard. You place them in the shaft of the key cap.
According to: =211116&specId=12967&tcId=238]http://uk.hardware.info/productinfo/benchmarks/31/keyboards?products[]=211116&specId=12967&tcId=238
Max keypress: 104
Force to press key: 56grams
Spacebar: 68gram
As for lighting effect.
Can be cycled through function key:
Breating light is standard
Single zone only (typing zone from ` to right CTRL) - breathes
Constant on (all keys)
Constant on (typing zone only)
Off
Strobe F1-F12
Custom preset 1/2 (press to choose which key is illuminated)
1x dedicated lighting disable
Brightness adjust for 6 level
Function display: Num/cap/scoll lock. Game mode, polling rate select, and turbo function active or not.
Pictures
Box
KB
Bottom
Palm rest
Key
Accessories
Cable
Full unboxing/pic: http://abload.de/gallery.php?key=zPrJnCtx
Max keypress: 104
Spacebar: 68gram
Off
Strobe F1-F12
Pictures
Box
KB
Bottom
Palm rest
Key
Accessories
Cable
