1 - 5 of 5 Posts
after OCing this is where i'm at... i need help making adjustments, i'm at 3.8Ghz and hit about 77C after 4 hrs of prime95 large data. then blue screen of death.
turbo mode - dis
BCLK - 190
DRAM Freq - 1600 8-8-8-24
CPU Volt - 1.30625
QPI/DRAM - 1.25
DRAM Volt - 1.66
CPU DIFF - 800Mv
APCI 2 - Enable
everything else os auto.
To be honest with you, you need to get your temps down below 70C. You are greatly reducing the life span of your CPU at those temps.
Also, what type of CPU are you using?
Edit: Just realized you are using an I7, which in itself puts out some of the craziest heat I have ever seen. I would open a window and pray. Otherwise, think about going water or go with a better CPU cooler such as a thermalright Ultra Black or my favorite, if you can find one, a Thermalright T.R.U.E Copper. This is just my personal opinion, as I have NEVER like anything Coolmaster puts out.
Another thing I forgot to ask you is did you just recently reseed the processor b/c you could have a bad seed between the heatsink and CPU.
1 - 5 of 5 Posts
