1 - 7 of 7 Posts
I got a trojan the other day because of some pictures (wallpapers that I downloaded the other day and I had to reinstall windows on to my computer. After I did a problem started to occur alot whenever I tried to use my computer it would come up with a blue screen saying some stuff and then it would restart I wrote down what I could and I was wondering if anyones seen it and can help me and Ill add more to it if it keeps happening.<br><br>
"A Problem has been detected and windows has been shut down to prevent damage to your computer."<br><br>
thats the first line to it. Someone please help me I really need to know what it could be????????<img alt="" class="inlineimg" src="/images/smilies/confused.gif" style="border:0px solid;" title="Confused"><img alt="" class="inlineimg" src="/images/smilies/confused.gif" style="border:0px solid;" title="Confused"><img alt="" class="inlineimg" src="/images/smilies/confused.gif" style="border:0px solid;" title="Confused">
The exact message on the blue screen can tell you a lot about your issue. Usually there will be a STOP message. Post up that info, and we may be able to help you better. There is a way in Windows to disable automatic reboot on BSODs (so you can read the error messages more easily), though I can't recall it off hand. Search through the forums as it's probably posted here somewhere.
I have like read it fully and it says theres a error with the hardware and or software. I had to reinstall windows XP professional 4 times, and it keeps happening. The hardware to my PC seems fine and at the end of the message it says its dumbing "something" memory. I dunno if any of that extra will help??
There should be a code or something like that. Can you take a picture/write down whats on the bsod?
Yeah, the exact code is key. It could be something as simple as moving a PCI card down one slot, or one of your components might be on its last leg.
Discussion Starter #6
OOOOOOOHHH. Ill do that when it happens again. Thank you by the way cause I saved for a long time for this thing and it being like this is like really nerve racking
We've all been there before. Good luck. <img src="/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" />
1 - 7 of 7 Posts
