1 - 9 of 9 Posts
Ok, I don't know if it is the mobo or ram or cpu or vid card, but I get a bluescreen everytime 10 min into game. I recently upgrated to another gig ram, (patriot and one non brand ram) included to my xms ram. Now, I put the ram speed to 166 because nothing else would boot. I wasn't getting bluescreens till today. Now, I doubt it the hd so it may be the mobo is incompatible with 4 sticks? Or what? I'm totally confused. If I downclock my oced vid card it still crashes so I don't think its the card. What you guys think?
Well.. the mixture of all those RAM brands is asking for trouble. Pull out the unmatched sticks and try with the XMS only.<br />
<br />
Also, four sticks will give a performance hit on AMD systems, but should not result in BSODs
ive been getting BSOD's lately too, i think its my ram too, or from overclocking (is that possible?)
Could be due to overclocking.... although generally other symptoms occur before BSOD's (freezing, failure to boot)<br />
<br />
Run memtest86
i dont have any floppies, and i dont even know if my floppy drive works. and im all out of cd's too, what a bust
I believe you can get memtest86 in an ISO that when properly burned to a CD-ROM is bootable.
Since you have new RAM introduced to your system, then I think you have your culprit. Just set the RAM timings at moderate so as to make room for compatibility. Like, If your RAM timings are 6-2-3-2(based on auto-detect from your original XMS), try to start from 8-4-4-3 and work from there. Tighten it a little and run memtest.<img alt="" class="inlineimg" src="/images/smilies/thumb.gif" style="border:0px solid;" title="Thumb">
Also, have you tried upping your vdimm a bit? That may help stabilize your memory.
Discussion Starter #9
I tryed upping vdimm, loosening timing although its only running at 178mhz because 200 1:1 wont boot. If i only put the xms it works good. But 2gb ram is a lot better than 1 in some games I play. It makes a huge amount of difference.
1 - 9 of 9 Posts
