Bluescreens
1997 Views 37 Replies 16 Participants Last post by  Enjoi
alright so i just did a complete reinstall of windows because i was getting bluescreens and every internet explorer,firefox i tried kept crashing etc. And i keep getting the same problem with this fresh reinstall of windows.
sometimes my Windows Explorer fails, or Shadow Copy.
whats the problem?
1 - 20 of 38 Posts
Have you tried another browser such as Firefox (far better IMHO) to see if it is just an IE issue?
thats what i meant by different internet explorers lol. Firefox crashes on me every 10 minutes
whats the problem?
Got something plugged in through USB that might be sucking a way too much power than it should be and no driver/corrupted driver to regulate it?
possibley your ram has gone bad, but I doubt it
ive tested my RAM,HD's, everything works fine, and ive plugged nothing new in that would do this
I am sorry man but I really cannot think of anything else then, maybe your CPU? is it overclocked? or your GPU?
BTW I gotta go to bed man, sorry I will help you when I wake up
im still having this problem, its pissing me off lol.
i reinstalled windows and my computer keeps crashing.It doesnt bluescreen as much but my web browsers continue to crash..mainly when im on a webpage that uses flashplayer.
Opera just crashed on me lol, this is the Detailed report.
Problem signature:
Problem Event Name:APPCRASH
Application Name:eek:pera.exe
Application Version:9.64.10487.0
Application Timestamp:49a6659c
Fault Module Name:Opera.dll
Fault Module Version:9.64.10487.0
Fault Module Timestamp:49a665ae
Exception Code:c0000005
Exception Offset:002b273d
OS Version:6.0.6000.2.0.0.256.1
Locale ID:1033
Additional Information 1:8d13
Additional Information 2:cdca9b1d21d12b77d84f02df48e34311
Additional Information 3:8d13
Additional Information 4:cdca9b1d21d12b77d84f02df48e34311
Anybody know what my problem is?
opera.exe, i have never heard of that, possibly a virus? try finding that program and deleting it or stop it from starting up in run -> msconfig
lol.
thats a web browser i use. and idont believe its a virus, i ran CCleaner,i checked my HD's etc.
lol.
oh, very strange so it still did this after you did a clean install...Did you do a quick format or full format?
Do you have a anti virus? Such as AVG? If not I would recommend getting AVG free edition. And search google for SUPERAntispyware and download and install that and do a full scan and see if it comes up anything.
i did a full format.
as for the virus stuff, ill run another scan.
Sounds like a memory problem to me, did you use Memtest and if so how long for?
After a clean fresh install, how can it be a software issue. Unless he has got wrong drivers installed.... gl,
It really sounds like faulty hardware. It can be your RAM like they said, or your PSU ,
No reason for a BSOD off a clean install ,, try running memtest... gl,
Well, if you keep reformatting and you BSOD, its a hardware problem.
I can see in the Opera crash, the exception code: c0000005... c0000005 = 0x00000005 = 0x5 (in Microsoft terms) and means that a exception has occurred by a driver that attempted to access memory in an area that it should not have, or the memory address was bad.
If you have run memory tests, that show no fault in your memory modules, it is most likely the result of a non-Microsoft program that you installed that is not agreeing with Vista's memory access regiment.
You may need to uninstall non-microsoft programs you installed after you reloaded Vista, and then try to determione which program you have insttalled that Vista doesn't like (or which program doesn't like Vista).
EDIT: If you decide to Reinstall Vista again, install only what you need in the way of drivers... no Firefox/opera or any additional programs. You'll find the problem will manifest itself after running a new installed program for a while. If you go and install 3 programs all at once, you will not be able to identify the offending program.
Just noticed that you are running "ultimate' my bad, so some additional information... this can also be a general access violation.
This error can have some additional meanings in the business, enterprise, and ultimate editions of Vista. It can be caused by Windows services that need to be running, but are not, specifically internet related services. Is your Windows firewall running? If so, in conjunction with another software firewall on your computer?
What specific errors are you showing in your System Event Log?
memtest shows no errors, just ran AVG again and no virusses.
heres some errors from the System Event Log
Problem signature
Problem Event Name:BlueScreen
Locale ID:1033
Files that help describe the problem (some files may no longer be available)
Mini031309-01.dmp
sysdata.xml
Version.txt
View a temporary copy of these files
Warning: If a virus or other security threat caused the problem, opening a copy of the files could harm your computer.
Extra information about the problem
BCCode:3b
BCP1:00000000C000001D
BCP2:FFFFF80001EA3CEA
BCP3:FFFFF9801B6F5210
BCP4:0000000000000000
OS Version:6_0_6000
Service Pack:0_0
Product:256_1
Server information:2473ff0e-a63a-436c-8979-3f82fedf90a4
Problem signature
Fault Module Name:NPSWF32.dll
Fault Module Version:10.0.22.87
Fault Module Timestamp:4987a8b1
Exception Offset:0005b314
Locale ID:1033
Problem signature
Problem Event Name:WINDOWS_WCP_OTHER_FAILURE2
OsVersion:6.0.6000
File:base\\wcp\\manifestparser\\hashverify.cpp
Function:Windows::ManifestParser::Rtl::CmsVerifyFileHashes
Line:547
Status:c015001b
Locale ID:1033
poqexec.log
Cbs.log
memory.hdmp
minidump.mdmp
Test new RAM even if memtest comes back with no errors.
1 - 20 of 38 Posts
