[BMR]Shocking HD5770 CrossFireX Results
35749 Views 150 Replies 87 Participants Last post by  wermad
Shocking Radeon HD5770 CrossFireX Results
Pros:
As of late November, Newegg is selling a few Radeon HD5770 cards at $164.99; three of them will set you back less than $500. Consider the fact that this combination smokes all of the following cards: GTX285, HD5870, GTX295, and beats the HD5970 in a couple scenarios with the Far Cry 2 and Resident Evil 5 benchmarks. If that's not a bargain, I don't know what is. There is an additional cost in system complexity, and partial incompatibility, however. You don't want to go this route if your favorite game is World in Conflict, at least until performance is addressed in a driver update.
Radeon HD5770 CrossFireXTM earns a Gold Tachometer Award, because it delivers an unprecedented level of performance at the $500 mark. Not only that, it's budget friendly in another way; you don't have to come up with all the cash up front. You can buy one card now, and have a guaranteed upgrade path. What makes this combination more worthy than CrossFireX combinations in the past is its scalability with first generation drivers. This is the first time an entirely new architecture has come out of the gate with this level of stability and performance in a multi-GPU arrangement.
Cons:
One performance disadvantage to CrossFireXTM is the fact that only the memory of one card is in use. The other RAM just sits there, idle. So, in all of our tests, we were working with 1GB of GDDR5. At our maximum testing resolution of 1920x1200, that wasn't a problem. At 2560x1600, or with multiple monitors, it could have become a handicap. On the whole, we went looking for some excellent performance scaling and we found it. We also found very reasonable power requirements and operating temperatures, both well established traits of the entire HD5xxx series.
Power Consumption:
The three Radeon HD5770 cards pulled 77 (196-119) watts at idle and 388 (507-119) watts when running full out, using the test method outlined above. That works out to 26 watts and 129 watts per card, which is a little bit above the factory numbers of 18W at idle and 108W per card under load. I attribute most of that to me manually setting the fans to a constant 100%, and to the load that FurMark put on the CPU. As I mentioned before, these are very reasonable power numbers for a 3-GPU setup, and well within the range that most PSU can provide. No need for a 1,000 watt power supply to run these at full power, I made do with my trusty single-rail 750W Corsair. I even had one PCI-E cable to spare.
http://benchmarkreviews.com/index.ph...=408&Itemid=72
Status
Not open for further replies.
1 - 20 of 151 Posts
Hang on this is the same as any Multi-GPU setup
Yeah. That's just the way it works...sadly.
i was looking for this benchmark ! thank you .I ll sell my 4870 and get 2 5770 and when i will have enough Benjamins for 3rd i ll thnk of it
Are the 5770's DX11 ready or not?
yes they are.
Cons:
- Only 1GB of memory available, 3GB paid for
Stupid con. All multigpu setups work this way and your not buying vram, your buying multiple video cards.
http://benchmarkreviews.com/index.ph...1&limitstart=1
Very much so.
Yup, server just went down.
AND NOW IT'S BACK...!
Thanks. Your right.. They just disappeared off the web. I think I just killed them
Is this really shocking?
Is not the first time we see 2-3 lower end cards beating a higher end card in price and performance. That's why lots of people still have older SLI/CF setups
So at 1920x1200 do you really need 3 of these? I'd rather go 5870 for an easier single gpu solution that would still run games fine at most settings. However still awesome performance for $500.
The utilization of only 1GB of vram is too much of a con for me to seriously consider this card array. Higher resolutions+higher texture packs in future games will eventually demand more than more than 1GB storage on gfxcards. Although, quite impressive for what you pay for.
Well, it's the same scenario on your 4870X2. 1GB of ram per gpu, but it is mirrored, so only 1gb is utilized in reality. Just how crossfire / SLI works.
This is IIRC, of course.
better get a 2 or 3GB card then for those higher resolutions then.
Shocking
I've pretty much conceded that although they may never wise up and make a single slot version of this card, I'm probably going to buy one anyway as it's a little shorter and more energy efficient (and a decent bit faster) than my HD4850.
Judging by the initial Dirt 2 benchmarks I've seen, they're just barely capable of running certain DirectX 11 features at 1680x1050 with 4xAA. And that game doesn't make the best use of DirectX 11 so we don't really know where it goes from there. We could see things getting better (frame-rate-wise) thanks to the optimizations in the API, or we could see them getting worse as developers add a ton of eye-candy.
A pair of these cards should do nicely though, at least from what we've seen so far.
You never know what the AIB's might make when availability gets better.
There is a single slot GTX260 after all.
I found after testing that my pair of 5850's provides the same framerates as my pair of 5870's at 1920x1200.
At higher resolutions, undoubtably, my 5870's would pull ahead but I have no interest in going into a larger monitor so its moot.
It's nice to see the lower cards scaling equally well in crossfire (tri-fire in this case).
NOPE. If it's not in the reference design it won't be fabricated. The single slot 260 is a fluke and impossible to find. Venders looking to refresh the reference designs typically just throw on shoddy aftermarket heatsinks and call it a "super" version.
1 - 20 of 151 Posts
Status
