1 - 20 of 21 Posts
Watercooled Railgun
I get a bunch of random characters when clicking on it Dark, but thanks for the heads up
Burning up my Atrix for the sake of science may be what i need to change smartphone
Could always use a backup phone and make it a slave BOINC cruncher until needed lol. Tried that with my Casio commando since it wont die but I cant find the NativeBOINC app for it. Hope this works so I can put it to good use.
Watercooled Railgun
Originally Posted by DarkRyder View Post
you need to right click and save as. its an .apk file made for the android OS
Will try it out
is anyone running arm projects? the only one ive tried (albert) takes days to complete 1 WU lol
Discussion Starter · #8 ·
yeah i run asteroids,pogs, and wcg on my s4. runs fine. few hours per wu.
Originally Posted by Tex1954 View Post
No wonder your battery don't last so long!
LOL!
i have it setup so it only runs when the phone is plugged in and the battery level is above 90%, so when i talk to you boinc isnt running. lol
Galaxy S4 results:
asteroid
http://asteroidsathome.net/boinc/results.php?hostid=44930
pogs
http://pogs.theskynet.org/pogs/results.php?hostid=10264
wcg
http://www.worldcommunitygrid.org/ms/device/viewDeviceStatHistory.do?deviceId=2427160&deviceType=B
guess they do run long... i coulda swore they were short wu's. i dunno
edit: looks like some wu's for asteroid are short...
LOL!
Galaxy S4 results:
asteroid
pogs
wcg
Someone should take an old Pentium 4, run it and see if the work units complete faster on that versus the Galaxy S4 CPU units. (i know there's architectural and OS differences, but still...)
Also there is massively more POWER required to run a pent-4... I have one, with HT... it's slow as dead dino-doodoo...
LOL!
ARM work units are labeled are under the "cpu" category, but i don't want to waste energy on cpu processing on my computer. is there a way to disable cpu units on my computer and still get arm units sent to me?
Well, you can set a different location for your computer vs. PDA... use default for PDA and set WORK to not allow CPU units in the project preferences... then set your home computer (or whatever) location to WORK in the view computers detail.
Might be somewhat project dependent too..
1 - 20 of 21 Posts
