61 - 72 of 72 Posts
Not New to Overclock.net
Guys, is there any way to set different concurrency for different GPUs on the same platform?
Separate clients. Ignore GPU 1 in one client, and GPU 2 in another.
Hm. That's a brilliant approach. I'll create .bat files which I'll place in the Startup directory (since the rig I want to do this is on Windows, alas).
Thanks! :cheers:
Not so new anymore...
Unfortunately it seems the Event Log only keep a certain amount of records and I can't go back to the time where I made the change. However, after I made the change I kept noticing the "communication deferred" appearing on the project tab. I might just be that.
I'll continue poking around and I'll save the log of this happens again.
Thanks for your help. :cheers:
Womp Womp
Same here, totally forgot to log in this past week!
Fluffy Fennec Foxes!
Prize money received, wooooohooooooo!
26 days to receive, that's so much nicer than the Wikia days!
61 - 72 of 72 Posts
