1 - 5 of 5 Posts
Heres my system
Aspire Cruiser 420 Watt PSU
AMD 3200 64
2 GB corsair platinum
300 GB 7200 Western Digital
NVDIA 7800GTX
Gigabyte k8xn SLI neForce 4 MOBO
Blah blah blah
heres the issue...
no problems at first build...then...for some reason when i turned system on...the monitor would not have signal....i reset the bios...and nothing....
then...poof everything came on....
well this has been happening for months now.....moslty i just leave system on...but if i have to restart or computer gets disconnected whatever....i seem to have this issue....the video card and all fans have power ( i felt the fan on the card blowing ) but its like the system isnt clcying all the way....the USB ports done get power and sometimes neither does my keyboard...
the only ideas i have are a PSU issue or a mobo issue..once it is running it flies !!! jsut cant turn it off...afraid i may not get it up again...2 days this last time
please help
-=DRC=-Snyps
Make sure all your power connectors are solid, make sure it's a clean windows install. Some Gigabyte boards are picky buggers, I had the same thing happen on one a while back, had to keep resetting bios to get post, turned out to be a intermittant power supply. After putting in a new PS it did it occasionaly until i formatted and reinstalled windows
I suspect the PS ... you need atleast 24a on the 12+v rail for that system.
Im running a custom 350 with a 17 amp 12v.
AMD Athlon X2 4200+ @ 2.65ghz
ASUS A8N-SLI Premium
2x512 OCZ Titanium
eVGA 7800 GT CO (486/1200)
3DMark01: 30,106
3DMark03: 17,496
3DMark05: 8,133
3DMark05 CPU Test: 6,262
Keep an eye on the voltages ... watch for fluxations. Still leaning twards the PS.
BTW... never go by the "watt" rating alone because it's very missleading!
The 12v+ rail is a very good indicator of the PS's true potential.
You have an X2/7800 etc... a lame PS is more trouble than most people realize.
I can not gurrantee that's your problem but it's a very good possibility.
1 - 5 of 5 Posts
