1 - 6 of 6 Posts
is there a key you can press on startup for this board to get to a boot menu?
or do i have to go into the bios to change my boot order if i want to boot to a different hard drive everytime?
motherboard - http://www.asus.com/products.aspx?l1...68&modelmenu=1
i read through the manual like, 2 times, and it doesn't say anything about that so i don't know...
Originally Posted by Enigma8750 View Post
F8 Will give you options but i dont think that boot sequence is there
the F8 key did exactly what i wanted it to do. it brings up a menu where i can select which device i want to boot from, thats all i wanted
thanks
I have a setup that has XP on a SATA drive and windows 7 beta on a IDE drive, and I have to go into the bios and change which harddrive is booted first to change the boot order. Ive got a M4A79T Deluxe
Just hit the f8 key and you can do it also
1 - 6 of 6 Posts
