Didnt the HDD come with a Cable and instructions? I know mine did.
Originally Posted by halifax1 ![]() Use the HP program: http://h20000.www2.hp.com/bizsupport...reg_R1002_USEN That's what I've done when needing to flash a 360 in DOS. It should make it bootable. You could also try NTFS4DOS. This is why I go for the preformatted drives since sometimes it's confusing on the best method for flashing the disk drive to work on 360. I'll try finding you a step by step guide. http://beta.ivancover.com/wiki/index..._Drive_Upgrade Best method is using HDDHackr. That site also has the hddss.bin that you need for the 120GB drive. Edit: Realized you need to make your own.. Should give you steps on what to do. Try the HP bootable program or you can use iPrep I believe. Scroll down and you can download the .RAR file. Cheers. |
Originally Posted by SeanEE89 ![]() I think I will give iPrep a try first. Where do I find the hddss.bin though for the 120GB drive? also what do I do with it just place it in the new drive or do I run it? |
Originally Posted by halifax1 ![]() The hddss.bin for the 120GB drive is on that page. That's the file you need. You load that with HDDhackr like it says on that link. You have to do it in DOS. |
