1 - 9 of 9 Posts
Overclock Failed...
There should be a BIOS setting to turn off CPU fan monitoring.
Originally Posted by pac0tac0 View Post
so i have a watercooled setup and i do not use a fan on my cpu header is there any way to get past the cpu fan error when booting? my mobo is an asus m4a78t-e.
i just dont need this loud 120mm fan making noise in my case.
Tell the BIOS to ignore CPU fan speed, might work.
Discussion Starter #9
Originally Posted by Schmuckley View Post
it's under the "Hardware Monitor" tab
fan speed>ignore
perfect thank you thats what i needed
Originally Posted by Costfree View Post
Or just hook up your exhaust fan given that you still have one.
i already have one an antec 3 speed pulling air though my rad, no point in putting 2 fans on one radiator.
1 - 9 of 9 Posts
