Originally Posted by
funky882
is there a borderlands benchmark tool included with the game?
Yes, you just need to launch the game with some parameters, I assume you use Steam, so go to Borderlands in Steam. Right-click it, click Properties, under the General tab, click on "Set Launch Options..." and type/paste the following:
timedemo1_p -benchmark -seconds=60 -novsync
You can change the time accordingly if you want. The log/result files will be under Documents>My Games>Borderlands>WillowGame>Logs>"benchmark result/log file"
Hope it helped!
