1 - 5 of 5 Posts
Hi i overclocked my cpu like half a year ago its still running stable at 4.0 GHz<br />
its an Intel Pentium 4 515 2.93 GHz 1MB L2 533 MHz FSB<br />
Family: F Model: 3 Stepping 4 <br />
Ext. Family: 0 Ext. Model: 0 Revision: 0<br />
seems that one guy made 5281 MHz with the same processor with the same stepping exactly the same processor as mine<br />
when i raise the fsb over 184 MHz x 22 <br />
i cannot boot anymore my pc wil automaticly reset to default speeds<br />
its an Gigabyte GA-8S648FX LGA775<br />
now i need to know what my bottleneck is<br />
is it my PSU it is an 300 Watt generic psu<br />
is it my mobo ? <br />
its ok if nobody knows but maybe from the symtones u see what it is <br />
if i overclock it to 4.00 GHz and clock some past that i made 4200 MHz CPU-Z verrified its an +10% incraise voltage and my mem is not 1:1 so the mem is not the problem
Gigabyte boards arnt the best overclockers, but the biggest problem I see is the PSU. At <b>minimum</b> you should have a 400W PSU powering that system. 500W to be safe.
have you tried raising the vCore manually? you might not have enough vCore to sustain that overclock.
Discussion Starter #4
i already broke my past PSU after some time it woudnt even boot unless i underclocked it <br />
but i ordered me a new case Gem X-Gear Silver with a 400 Watt PSU included
Discussion Starter #5
my mobo only gives the options to raise the vcore<br />
- 5 %<br />
- 7.5 %<br />
- 10 %
1 - 5 of 5 Posts
