BottleNeck?
692 Views 16 Replies 8 Participants Last post by  Chandlermaki
e8400
4Gig Ram
ASUS P5E Deluxe
If you put 2 x 5770, will it bottleneck?
edit: Or 2 x 4890
1 - 17 of 17 Posts
Yes, you need quad-core for those cards to run wild. 4890s included.
Would 9550 handle it?
That would be worse than the E8400.
Hmm I'm lost
Why?
Originally Posted by Cyberbot View Post
Why?
Yeah I thought Q9550 would be better than a duo core o_O
XD
Thought you meant Phenom 9550. Damn me and my AMD mind.
You mean Q9550 correct? It would handle 2x 4890s wonderfully.
Ninja Edit: well looks like that got sorted out in the interim
I think he mean't the AMD 9550 and he would have still been wrong, so both the AMD and the Intel 9550's would be better than a stock e8400, and yes if you'd like to run dual 4890's or 5770's you'd want maybe a AMD PII x3 or any newer quad should work.
Then Q9550 it is.
thanks guys.
XD
lol, since this is posted in the ATI forum I wont blame you for it
The E8400 will not bottleneck a Crossfire setup. Especially not when overclocked to 4.0Ghz.
E8400 beats the PH 9550 gaming wise.
That's besides the point, a Q9550 would be a great upgrade from an E8400.
Assuming he gets a good chip and he is willing to keep i at 4.0 GHz 24/7. Our solutions are overall better than an overclocked E8XXX to 4.0.
Guys I'm just wondering, would a Q9400 bottleneck two 5770's in crossfire?
I'd like to know if I'd have to overclock the Q9400 or not, though I most likely will I just wanna know if the 2.66GHz will be enough.
Thanks in advance
Thanks in advance
It'll be better than the E8400, probably wont bottleneck. I'd still get a 9550, honestly.
1 - 17 of 17 Posts
