Originally Posted by rendl42 Ok so buying on ebay is kinda asking for it, but running this supposed platinum edition I normally get some artifacts. Does anybody know how to check whether the card is truly a PE or just a flashed pro or XT? Thanks heaps.. |
Originally Posted by mfillpot Get the model or serial number off of the card and google it. |
Originally Posted by rendl42 I tried that when I received it but nothing. Even tried calling ATI, but they are slow as hell to answer their phones. THanks... any other ideasS? |
Originally Posted by mfillpot post the identifiers here and we will search for you. |
Originally Posted by rendl42 What exactly do you mean by identifiers? Can this be retrieved by a tool or do I have to pull the card? thanks for your help!! |
Originally Posted by ThE_GeNeRaL whats its clock speeds??? |
Originally Posted by rendl42 S/N: e0408007218 P/N: 109-a26100-01 Clock speeds were set to the normal PE settings. I lowered them and still get strange clipping on the screen (only in windows) when doing the artifact test with Ati Tool. Thanks again. |
Originally Posted by Tatewaki 109-A is the PCB number 102-A is the assembly number If the board is built by ATI, there will be both 109 and 102 number. If the board is built by Sapphire, then only 109 number will be there. The 102 number will be changed to something else |
