That is well within normal ranges. Voltage wouldnt be ur main problem, just temperatures. So just get some temperature monitoring programs (everest, speedfan etc etc) and check those out. Also to note, brisbane cores have faulty temperature sensors. You probably will need to add a 20C offset to the readings if not more. My processor will fail at the reading of 45C.
But to answer your overall question. The voltage is ok. And if your motherboard allows it, u could also push the chip farther as the stock voltage for ur processor is around 1.375-1.4V. Get it to around 2.7-2.8ghz if u can
Cheers and good luck,
S1L3Nt
S1L3Nt
