Hey guys,
Just a real quick post, can someone tell if it is common to get the blue screen of death while running prime95?
I'm testing for my 4ghz oc, i can pass OCCT, but Prime usually runs into the BSOD after about 40min to an hour. I know my voltages are low for the oc but i fugure Prime95 should let me know, not blue screen.
Specs:
CPU Clock Ratio: 20x
QPI Link Speed: 36x
BASE Clock: Enabled
Clock FQ: 200
Uncore Frequency: 17x
Performance Enhance: Turbo
Sys Mem Multiplier: 8.0
Dram Timing: Auto
LoadLine: enabled
CPU vCore: 1.26250v
QPI/VTT: 1.20v
IOH Core: 1.120v
Dram Voltage: 1.64v
CPU PLL 1.800V
Advanced CPU Features:
Intel Turbo Boost Tech. [Disabled]
CPU Cores Enabled [All]
CPU Multi Threading [Enabled]
CPU Enhanced Halt (C1E) [Disabled]
C3/C6/C7 State Support [Diabled]
CPU Thermal Monitor [Enabled]
CPU Eist Function [Disabled]
Virtualization Technology [Enabled]
Bi-directional PROCHOT [Enabled]
All power assist/saving features disabled in bios.
Cheers.
Specs:
QPI Link Speed: 36x
BASE Clock: Enabled
Clock FQ: 200
Dram Timing: Auto
LoadLine: enabled
CPU vCore: 1.26250v
QPI/VTT: 1.20v
IOH Core: 1.120v
Dram Voltage: 1.64v
CPU PLL 1.800V
Cheers.
