1 - 20 of 30 Posts
Ok so I just got my SSD and installed windows 7 (took me 3 trys to set it up perfect I don't want to redue it again, it cant be good for my drive) on it and had my 2 other WD Blacks for other files (Games, DL's, some drivers, ETC). I installed skype, AMD 11.4 drivers, HW monitor, CPU-Z on my HDD's (nothing important) So I decided to raid0 my 2 drives. I did and it deleted everything on them and tried to boot up only to get a BSOD. I tried IDE & ACHI and still BSOD. I tried to delete the raid0 config. and still get a BSOD..
I dont want to reinstall windows 7 on my SSD and set it up all over again. Is there a way to fix this? My HDD's had nothing important on them so I dont understand why i'd get a BSOD on bootup.. Would appreciate the help.
Thanks!
Originally Posted by Stealth2o
Another possibility is that your overclock might be unstable. Have you tried to reset bios?
Ive reset everything and still bsod. this all happaned after I did my raid0 on my wd blacks. I dont believe its my ram.
Discussion Starter · #9 ·
Originally Posted by Stealth2o;13076084
Bad sata cable, or port. Try using a different sata cable.
Lol i'll try that, but I dont think thats the issue either. Could it be I didnt have the raid config. drivers? I didn't install anything.
The only thing I dont get about this is why would it BSOD??? WHY? I didn't have anything on my HDD's except junk.. Music,League of legends, HWmonitor, GPU-Z,AMD 11.4 Drivers, Skype, Razer mamba&lycosa drivers, Avast antivirus, and I think thats about it. Nothing that should cause a BSOD if deleted tho.
Yes, raid drivers are necessary. What you need to do is download the raid drivers from another computer, put them on a flash drive. Boot with your Windows 7 CD, and theres an option to choose to install (load) drivers when you do a Custom windows installation.
· Bigger is Always Better
What BSOD error are you getting? I'm making some assumptions:
All this hardware has been working in your rig
Your overclock is stable
The SSD is the only new part
So you reset your CMOS and deleted the RAID and it's still getting a BSOD?
Need more info Bro. It sounds offhand that you have a failed overclock and/or a bad SATA port as mentioned above by Stealth
He doesn't need to boot from his Win 7 DVD to install raid drivers, unless he's running a RAID on his boot drive. I thought the WD Blacks were just for data.
Just copy the drivers to a USB and load them like any other utility software.
I'm a little out of date on my troubleshooting skills. LoL
Discussion Starter · #16 ·
Reset my CMOS and deleted raid0 and still BSOD..
Disconnect the WD drives completely. Boot with one stick of memory. Take your rig to the minimum and if you have to, reset the CMOS one more time. Disconnect the AC cord and short the pins or hold the button for several seconds. Remove the CMOS battery if you have to. Then load fail-safe defaults or factory defaults from the BIOS. If THAT doesn't work, I'd have to say that your Windows 7 install is corrupted
You can try to use the Win 7 install disk and try to repair it. There is an option whether to load it fresh or repair. Try the repair option.
Discussion Starter · #20 ·
i tried differnet sticks of ram and I dc/ed the WD drives already. i'll try a new sata slot and reset CMOS again. but if this doesnt help ill just do a fresh install... Again
1 - 20 of 30 Posts
