1 - 12 of 12 Posts
· OS - Windows 10 Pro
· x64
· Original OS was windows 8.1
· system is around 3 years old
· Intel Core i7-4790K CPU @ 4.00GHz
· 6GB Gigabyte GTX 980 Ti G1 GAMING
· MAXIMUS VII RANGER
· 850W Corsair RM850i
· Corsair Vengeance Pro Series 16GB (2x8GB) DDR3 2400Mhz
Bluescreen View
Dump File : 032816-16921-01.dmp
Crash Time : 28/03/2016 23:34:24
Bug Check String :
Bug Check Code : 0x00000124
Parameter 1 : 00000000`00000000
Parameter 2 : ffffe000`fe8f0028
Parameter 3 : 00000000`be000000
Parameter 4 : 00000000`0100110a
Caused By Driver : hal.dll
Caused By Address : hal.dll+35f1f
File Description :
Product Name :
Company :
File Version :
Processor : x64
Crash Address : ntoskrnl.exe+142760
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\WINDOWS\Minidump\032816-16921-01.dmp
Processors Count : 8
Major Version : 15
Minor Version : 10586
Dump File Size : 258,292
Dump File Time : 28/03/2016 23:35:26
Im wondering if anyone could help me out, recently ive been getting bsod while playing games. I run multi montiors so while im playing i will have a firefox tab open to listen to music or watch youtube videos along with a skype call. Ive noticed that The crashes usualy occur while i have something other than the game open, rarely it will crash randomly without anything other than the game open. Sometimes the pc will randomly shutdown and restart while playing games but the tempretures are fine. I usualy get 50-60°c on gpu, 40-50°c on cpu and 35-40°c on psu while playing games. I would like to know if i have to replace any parts and if so which ones? Thanks for any help.
SysnativeFileCollectionApp.zip 1298k .zip file
Discussion Starter #5
Originally Posted by Lantian View Post
if you installed the new 364.72 driver or before this than just roll back, this branch has a lot bsod and freeze problems for people
yeah, ive tried this but have had no luck.
Quickly Googling the issue, it could be due to a number of things. To save time and going through every little detail I would just reinstall Windows. After you have done that just install the basic drivers(like chipser and gpu) and try playing some games and go from there. If it fails during install it is definitely something hardware related. Make sure you create an image of your system and make sure you default your clocks.
wich driver di you try, as far as i can tell the whole 364 branch is bugged, for me tho only 364.72 introduced problems, thoug the 0124 code looks familiar, gonna do a quick check..
Synopsis:
A "stop 0x124" is fundamentally different to many other types of bluescreens because it stems from a hardware complaint. Stop 0x124 minidumps contain very little practical information, and it is therefore necessary to approach the problem as a case of hardware in an unknown state of distress.
Generic "Stop 0x124" Troubleshooting Strategy:
1) Ensure that none of the hardware components are overclocked. Hardware that is driven beyond its design specifications - by overclocking - can malfunction in unpredictable ways.
2) Ensure that the machine is adequately cooled. If there is any doubt, open up the side of the PC case (be mindful of any relevant warranty conditions!) and point a mains fan squarely at the motherboard. That will rule out most (lack of) cooling issues.
3) Update all hardware-related drivers: video, sound, RAID (if any), NIC... anything that interacts with a piece of hardware. It is good practice to run the latest drivers anyway.
4) Update the motherboard BIOS according to the manufacturer's instructions. Their website should provide detailed instructions as to the brand and model-specific procedure.
5) Rarely, bugs in the OS may cause "false positive" 0x124 events where the hardware wasn't complaining but Windows thought otherwise (because of the bug). At the time of writing, Windows 7 is not known to suffer from any such defects, but it is nevertheless important to always keep Windows itself updated.
6) Attempt to (stress) test those hardware components which can be put through their paces artificially. The most obvious examples are the RAM and HDD(s). For the RAM, use the in-built memory diagnostics (run MDSCHED) or the 3rd-party memtest86 utility to run many hours worth of testing. For hard drives, check whether CHKDSK /R finds any problems on the drive(s), notably "bad sectors". Unreliable RAM, in particular, is deadly as far as software is concerned, and anything other than a 100% clear memory test result is cause for concern. Unfortunately, even a 100% clear result from the diagnostics utilities does not guarantee that the RAM is free from defects - only that none were encountered during the test passes.
7) As the last of the non-invasive troubleshooting steps, perform a "vanilla" reinstallation of Windows: just the OS itself without any additional applications, games, utilities, updates, or new drivers - NOTHING AT ALL that is not sourced from the Windows 7 disc. Should that fail to mitigate the 0x124 problem, jump to the next steps. Otherwise, if you run the "vanilla" installation long enough to convince yourself that not a single 0x124 crash has occurred, start installing updates and applications slowly, always pausing between successive additions long enough to get a feel for whether the machine is still free from 0x124 crashes. Should the crashing resume, obviously the very last software addition(s) may be somehow linked to the root cause.
If stop 0x124 errors persist despite the steps above, and the harware is under warranty, consider returning it and requesting a replacement which does not suffer periodic MCE events. Be aware that attempting the subsequent harware troubleshooting steps may, in some cases, void your warranty:
8) Clean and carefully remove any dust from the inside of the machine. Reseat all connectors and memory modules. Use a can of compressed air to clean out the RAM DIMM sockets as much as possible.
9) If all else fails, start removing items of hardware one-by-one in the hope that the culprit is something non-essential which can be removed. Obviously, this type of testing is a lot easier if you've got access to equivalent components in order to perform swaps.
as i thought, when did this start happening?
Discussion Starter #8
Ok thanks for the help guys, ill try reinstalling windows with the basic drivers (along with a nvidia driver that is before 364) and give some games a try. ill post back if the problem still persists.
Discussion Starter #9
Ok so after reseting my pc and doing a fresh install of windows and main drivers including a non broken nvidia driver i am still getting bsod
Bluescreen View 040716-18937-01.dmp 07/04/2016 19:08:23 0x00000124 00000000`00000000 ffffe001`2dec8028 00000000`be000000 00000000`0100110a hal.dll hal.dll+35f1f x64 ntoskrnl.exe+141f80 C:\WINDOWS\Minidump\040716-18937-01.dmp 8 15 10586 201,156 07/04/2016 19:09:25
Upload that latest .dmp file please...
Every single one of the dump files posted in your OP has the 124 bugcheck. This being OCN the most common cause is a bad overclock.
As mentioned in the posting instructions please ensure all hardware is running at stock settings.
Assuming you're running stock, did you go through the steps mentioned in Lantians post?
The only explanation I can find is your CPU, you have WHEA errors, 0x124 bugchecks, close to every dump has been pointing towards GenuineIntel processes.
Have you made any changes in your BIOS at all?
The fact that this is happening on a fresh install is baffling and just further points toward hardware failure.
1: kd> lmnt
start             end                 module name
fffff801`35600000 fffff801`35625000   tm       tm.sys       Fri Oct 30 03:09:42 2015 (5632D166)
fffff801`35630000 fffff801`35647000   PSHED    PSHED.dll    Fri Oct 30 03:09:48 2015 (5632D16C)
fffff801`35650000 fffff801`3565b000   BOOTVID  BOOTVID.dll  Fri Oct 30 03:09:41 2015 (5632D165)
fffff801`35660000 fffff801`3566e000   cmimcext cmimcext.sys Fri Oct 30 03:09:42 2015 (5632D166)
fffff801`35670000 fffff801`3567c000   ntosext  ntosext.sys  Fri Oct 30 03:09:41 2015 (5632D165)
fffff801`35680000 fffff801`35719000   CI       CI.dll       Fri Oct 30 03:35:19 2015 (5632D767)
fffff801`35720000 fffff801`3577c000   msrpc    msrpc.sys    Fri Oct 30 03:34:46 2015 (5632D746)
fffff801`35780000 fffff801`357e2000   FLTMGR   FLTMGR.SYS   Fri Oct 30 03:09:58 2015 (5632D176)
fffff801`357f0000 fffff801`35815000   ksecdd   ksecdd.sys   Fri Oct 30 03:38:43 2015 (5632D833)
fffff801`35820000 fffff801`358c5000   clipsp   clipsp.sys   Fri Oct 30 03:37:15 2015 (5632D7DB)
fffff801`358d0000 fffff801`35995000   Wdf01000 Wdf01000.sys Fri Oct 30 03:24:27 2015 (5632D4DB)
fffff801`359a0000 fffff801`359b3000   WDFLDR   WDFLDR.SYS   Fri Oct 30 03:09:44 2015 (5632D168)
fffff801`359c0000 fffff801`359e3000   acpiex   acpiex.sys   Fri Oct 30 03:39:16 2015 (5632D854)
fffff801`359f0000 fffff801`359fd000   WppRecorder WppRecorder.sys Fri Oct 30 03:09:42 2015 (5632D166)
fffff801`35a00000 fffff801`35a98000   cng      cng.sys      Fri Oct 30 03:29:33 2015 (5632D60D)
fffff801`35aa0000 fffff801`35b30000   ACPI     ACPI.sys     Fri Oct 30 03:10:07 2015 (5632D17F)
fffff801`35b30000 fffff801`35b3c000   WMILIB   WMILIB.SYS   Fri Oct 30 03:09:42 2015 (5632D166)
fffff801`35b50000 fffff801`35b6f000   WindowsTrustedRT WindowsTrustedRT.sys Fri Oct 30 03:38:30 2015 (5632D826)
fffff801`35b70000 fffff801`35b7b000   WindowsTrustedRTProxy WindowsTrustedRTProxy.sys Fri Oct 30 03:38:29 2015 (5632D825)
fffff801`35b80000 fffff801`35b92000   pcw      pcw.sys      Fri Oct 30 03:09:42 2015 (5632D166)
fffff801`35ba0000 fffff801`35bab000   msisadrv msisadrv.sys Fri Oct 30 03:41:55 2015 (5632D8F3)
fffff801`35bb0000 fffff801`35c06000   pci      pci.sys      Fri Oct 30 03:29:30 2015 (5632D60A)
fffff801`35c10000 fffff801`35c22000   vdrvroot vdrvroot.sys Fri Oct 30 03:39:01 2015 (5632D845)
fffff801`35c30000 fffff801`35c4e000   pdc      pdc.sys      Fri Oct 30 03:09:51 2015 (5632D16F)
fffff801`35c50000 fffff801`35c69000   CEA      CEA.sys      Fri Oct 30 03:42:10 2015 (5632D902)
fffff801`35c70000 fffff801`35c92000   partmgr  partmgr.sys  Fri Oct 30 03:09:52 2015 (5632D170)
fffff801`35ca0000 fffff801`35d26000   spaceport spaceport.sys Fri Oct 30 03:34:45 2015 (5632D745)
fffff801`35d30000 fffff801`35d48000   volmgr   volmgr.sys   Fri Oct 30 03:09:49 2015 (5632D16D)
fffff801`35d50000 fffff801`35dae000   volmgrx  volmgrx.sys  Fri Oct 30 03:09:52 2015 (5632D170)
fffff801`35db0000 fffff801`35dcd000   mountmgr mountmgr.sys Fri Oct 30 03:09:48 2015 (5632D16C)
fffff801`35dd0000 fffff801`36093000   iaStorA  iaStorA.sys  Fri Apr 04 01:00:05 2014 (533DE7F5)
fffff801`360a0000 fffff801`36118000   storport storport.sys Fri Oct 30 03:34:05 2015 (5632D71D)
fffff801`36140000 fffff801`36159000   fileinfo fileinfo.sys Fri Oct 30 03:37:17 2015 (5632D7DD)
fffff801`36160000 fffff801`36198000   Wof      Wof.sys      Fri Oct 30 03:38:16 2015 (5632D818)
fffff801`361a0000 fffff801`361ec000   WdFilter WdFilter.sys Fri Oct 30 03:34:35 2015 (5632D73B)
fffff801`361f0000 fffff801`36408000   NTFS     NTFS.sys     Fri Oct 30 03:12:23 2015 (5632D207)
fffff801`36410000 fffff801`3641d000   Fs_Rec   Fs_Rec.sys   Fri Oct 30 03:09:42 2015 (5632D166)
fffff801`364d0000 fffff801`3655e000   mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Fri Oct 30 03:42:26 2015 (5632D912)
fffff801`36560000 fffff801`36570000   werkernel werkernel.sys Fri Oct 30 03:42:19 2015 (5632D90B)
fffff801`36570000 fffff801`365d5000   CLFS     CLFS.SYS     Fri Oct 30 03:09:54 2015 (5632D172)
fffff801`36600000 fffff801`3662e000   ksecpkg  ksecpkg.sys  Fri Oct 30 03:38:10 2015 (5632D812)
fffff801`36630000 fffff801`3666a000   mrxsmb20 mrxsmb20.sys Fri Oct 30 03:27:25 2015 (5632D58D)
fffff801`36670000 fffff801`366b1000   srvnet   srvnet.sys   Fri Oct 30 03:29:28 2015 (5632D608)
fffff801`366c0000 fffff801`366d4000   mmcss    mmcss.sys    Fri Oct 30 03:38:57 2015 (5632D841)
fffff801`366e0000 fffff801`366fe080   rzpnk    rzpnk.sys    Thu Sep 17 02:16:35 2015 (55FA0663)
fffff801`36700000 fffff801`3674e000   mrxsmb10 mrxsmb10.sys Fri Oct 30 03:27:22 2015 (5632D58A)
fffff801`36750000 fffff801`36776000   Ndu      Ndu.sys      Fri Oct 30 03:37:27 2015 (5632D7E7)
fffff801`36780000 fffff801`36794000   tcpipreg tcpipreg.sys Fri Oct 30 03:38:09 2015 (5632D811)
fffff801`36840000 fffff801`36960000   ndis     ndis.sys     Fri Oct 30 03:28:34 2015 (5632D5D2)
fffff801`36960000 fffff801`369d8000   NETIO    NETIO.SYS    Fri Oct 30 03:33:57 2015 (5632D715)
fffff801`36a00000 fffff801`36a69000   volsnap  volsnap.sys  Fri Oct 30 03:09:52 2015 (5632D170)
fffff801`36a70000 fffff801`36ab4000   rdyboost rdyboost.sys Fri Oct 30 03:35:23 2015 (5632D76B)
fffff801`36ac0000 fffff801`36ae5000   mup      mup.sys      Fri Oct 30 03:24:27 2015 (5632D4DB)
fffff801`36b00000 fffff801`36b1f000   disk     disk.sys     Fri Oct 30 03:09:50 2015 (5632D16E)
fffff801`36b20000 fffff801`36b80000   CLASSPNP CLASSPNP.SYS Fri Oct 30 03:09:57 2015 (5632D175)
fffff801`36ba0000 fffff801`36bb9000   crashdmp crashdmp.sys Fri Oct 30 03:38:20 2015 (5632D81C)
fffff801`36bc0000 fffff801`36e83000   dump_iaStorA dump_iaStorA.sys Fri Apr 04 01:00:05 2014 (533DE7F5)
fffff801`36e90000 fffff801`36f22000   dxgmms2  dxgmms2.sys  Fri Oct 30 03:13:10 2015 (5632D236)
fffff801`36f30000 fffff801`36f6b000   WUDFRd   WUDFRd.sys   Fri Oct 30 03:09:51 2015 (5632D16F)
fffff801`36f70000 fffff801`36f8a000   rspndr   rspndr.sys   Fri Oct 30 03:39:46 2015 (5632D872)
fffff801`36f90000 fffff801`36faa000   mslldp   mslldp.sys   Fri Oct 30 03:37:12 2015 (5632D7D8)
fffff801`36fb0000 fffff801`36fc6000   lltdio   lltdio.sys   Fri Oct 30 03:40:06 2015 (5632D886)
fffff801`36fd0000 fffff801`370e1000   HTTP     HTTP.sys     Fri Oct 30 03:29:26 2015 (5632D606)
fffff801`370f0000 fffff801`37113000   bowser   bowser.sys   Fri Oct 30 03:40:29 2015 (5632D89D)
fffff801`37120000 fffff801`37192000   mrxsmb   mrxsmb.sys   Fri Oct 30 03:26:42 2015 (5632D562)
fffff801`371a0000 fffff801`371b9000   mpsdrv   mpsdrv.sys   Fri Oct 30 03:37:43 2015 (5632D7F7)
fffff801`371c0000 fffff801`371fc000   ahcache  ahcache.sys  Fri Oct 30 03:09:45 2015 (5632D169)
fffff801`37200000 fffff801`3721d000   filecrypt filecrypt.sys Fri Oct 30 03:37:49 2015 (5632D7FD)
fffff801`37220000 fffff801`3722c000   tbs      tbs.sys      Fri Oct 30 03:41:53 2015 (5632D8F1)
fffff801`37230000 fffff801`3723a000   Null     Null.SYS     unavailable (00000000)
fffff801`37240000 fffff801`3724a000   Beep     Beep.SYS     Fri Oct 30 03:41:57 2015 (5632D8F5)
fffff801`37250000 fffff801`37264000   BasicDisplay BasicDisplay.sys Fri Oct 30 03:40:28 2015 (5632D89C)
fffff801`37270000 fffff801`37285000   watchdog watchdog.sys Fri Oct 30 03:39:37 2015 (5632D869)
fffff801`37290000 fffff801`3747d000   dxgkrnl  dxgkrnl.sys  Fri Oct 30 03:13:53 2015 (5632D261)
fffff801`37480000 fffff801`37492000   BasicRender BasicRender.sys Fri Oct 30 03:41:40 2015 (5632D8E4)
fffff801`374a0000 fffff801`374b9000   Npfs     Npfs.SYS     Fri Oct 30 03:09:42 2015 (5632D166)
fffff801`374c0000 fffff801`374cf000   Msfs     Msfs.SYS     Fri Oct 30 03:09:42 2015 (5632D166)
fffff801`374d0000 fffff801`374f3000   tdx      tdx.sys      Fri Oct 30 03:39:28 2015 (5632D860)
fffff801`37500000 fffff801`3750f000   TDI      TDI.SYS      Fri Oct 30 03:41:51 2015 (5632D8EF)
fffff801`37510000 fffff801`3755b000   netbt    netbt.sys    Fri Oct 30 03:35:40 2015 (5632D77C)
fffff801`37560000 fffff801`375f3000   afd      afd.sys      Fri Oct 30 03:32:12 2015 (5632D6AC)
fffff801`37600000 fffff801`37619000   vwififlt vwififlt.sys Fri Oct 30 03:37:27 2015 (5632D7E7)
fffff801`37620000 fffff801`3764b000   pacer    pacer.sys    Fri Oct 30 03:36:02 2015 (5632D792)
fffff801`37650000 fffff801`37662000   netbios  netbios.sys  Fri Oct 30 03:37:46 2015 (5632D7FA)
fffff801`37670000 fffff801`376e1000   rdbss    rdbss.sys    Fri Oct 30 03:25:43 2015 (5632D527)
fffff801`376f0000 fffff801`3777e000   csc      csc.sys      Fri Oct 30 03:25:37 2015 (5632D521)
fffff801`37780000 fffff801`37790000   nsiproxy nsiproxy.sys Fri Oct 30 03:38:00 2015 (5632D808)
fffff801`37790000 fffff801`3779d000   npsvctrig npsvctrig.sys Fri Oct 30 03:40:23 2015 (5632D897)
fffff801`377a0000 fffff801`377b0000   mssmbios mssmbios.sys Fri Oct 30 03:38:07 2015 (5632D80F)
fffff801`377b0000 fffff801`377ba000   gpuenergydrv gpuenergydrv.sys Fri Oct 30 03:39:54 2015 (5632D87A)
fffff801`377c0000 fffff801`377ea000   dfsc     dfsc.sys     Fri Oct 30 03:25:22 2015 (5632D512)
fffff801`377f0000 fffff801`37801000   CompositeBus CompositeBus.sys Fri Oct 30 03:41:36 2015 (5632D8E0)
fffff801`37810000 fffff801`37816000   AsIO     AsIO.sys     Wed Aug 22 11:54:47 2012 (5034AC67)
fffff801`37820000 fffff801`3782d000   kdnic    kdnic.sys    Fri Oct 30 03:41:45 2015 (5632D8E9)
fffff801`37830000 fffff801`37845000   umbus    umbus.sys    Fri Oct 30 03:37:25 2015 (5632D7E5)
fffff801`37850000 fffff801`37aa7000   tcpip    tcpip.sys    Fri Oct 30 03:26:39 2015 (5632D55F)
fffff801`37ab0000 fffff801`37b17000   fwpkclnt fwpkclnt.sys Fri Oct 30 03:10:03 2015 (5632D17B)
fffff801`37b20000 fffff801`37b4a000   wfplwfs  wfplwfs.sys  Fri Oct 30 03:36:36 2015 (5632D7B4)
fffff801`37b50000 fffff801`37bf1000   fvevol   fvevol.sys   Fri Oct 30 03:31:17 2015 (5632D675)
fffff801`38600000 fffff801`3862f000   tunnel   tunnel.sys   Fri Oct 30 03:36:11 2015 (5632D79B)
fffff801`38630000 fffff801`38652000   WdNisDrv WdNisDrv.sys Fri Oct 30 03:36:57 2015 (5632D7C9)
fffff801`38660000 fffff801`38671000   condrv   condrv.sys   Fri Oct 30 03:09:42 2015 (5632D166)
fffff801`386c0000 fffff801`386cd000   nvvad64v nvvad64v.sys Mon Mar 14 07:27:42 2016 (56E659DE)
fffff801`387e0000 fffff801`388a0000   peauth   peauth.sys   Fri Oct 30 03:32:55 2015 (5632D6D7)
fffff801`388a0000 fffff801`3894f000   srv2     srv2.sys     Fri Oct 30 03:30:24 2015 (5632D640)
fffff801`38950000 fffff801`389dc000   srv      srv.sys      Fri Oct 30 03:30:28 2015 (5632D644)
fffff801`38a00000 fffff801`38a58000   portcls  portcls.sys  Fri Oct 30 03:33:27 2015 (5632D6F7)
fffff801`38a60000 fffff801`38a81000   drmk     drmk.sys     Fri Oct 30 03:38:44 2015 (5632D834)
fffff801`38a90000 fffff801`38af8000   ks       ks.sys       Fri Oct 30 03:33:56 2015 (5632D714)
fffff801`38b00000 fffff801`38b61000   USBXHCI  USBXHCI.SYS  Fri Oct 30 03:32:00 2015 (5632D6A0)
fffff801`38b70000 fffff801`38ba8000   ucx01000 ucx01000.sys Fri Oct 30 03:34:40 2015 (5632D740)
fffff801`38bb0000 fffff801`38bd3000   TeeDriverx64 TeeDriverx64.sys Tue Sep 23 22:01:14 2014 (5421D18A)
fffff801`38be0000 fffff801`38c59000   e1i63x64 e1i63x64.sys Thu Mar 26 21:24:57 2015 (55146B19)
fffff801`38c60000 fffff801`38c7c000   usbehci  usbehci.sys  Fri Oct 30 03:27:04 2015 (5632D578)
fffff801`38c80000 fffff801`38cf5000   USBPORT  USBPORT.SYS  Fri Oct 30 03:27:18 2015 (5632D586)
fffff801`38d00000 fffff801`38d0c000   wmiacpi  wmiacpi.sys  Fri Oct 30 03:37:04 2015 (5632D7D0)
fffff801`38d10000 fffff801`38d3e000   HIDCLASS HIDCLASS.SYS Fri Oct 30 03:36:25 2015 (5632D7A9)
fffff801`38d40000 fffff801`38d47280   rzpmgrk  rzpmgrk.sys  Thu Sep 17 20:42:44 2015 (55FB09A4)
fffff801`38d50000 fffff801`38d7b000   intelppm intelppm.sys Fri Oct 30 03:09:51 2015 (5632D16F)
fffff801`38d80000 fffff801`38d8b000   acpipagr acpipagr.sys Fri Oct 30 03:42:18 2015 (5632D90A)
fffff801`38d90000 fffff801`38d9d000   NdisVirtualBus NdisVirtualBus.sys Fri Oct 30 03:38:26 2015 (5632D822)
fffff801`38da0000 fffff801`38dac000   swenum   swenum.sys   Fri Oct 30 03:42:20 2015 (5632D90C)
fffff801`38db0000 fffff801`38dbe000   rdpbus   rdpbus.sys   Fri Oct 30 03:10:15 2015 (5632D187)
fffff801`38dc0000 fffff801`38e40000   usbhub   usbhub.sys   Fri Oct 30 03:30:56 2015 (5632D660)
fffff801`38e40000 fffff801`38e4e000   USBD     USBD.SYS     Fri Oct 30 03:41:54 2015 (5632D8F2)
fffff801`38ec0000 fffff801`38ece000   ksthunk  ksthunk.sys  Fri Oct 30 03:42:01 2015 (5632D8F9)
fffff801`38ed0000 fffff801`38f57000   UsbHub3  UsbHub3.sys  Fri Oct 30 03:30:55 2015 (5632D65F)
fffff801`38f60000 fffff801`393e2000   RTKVHD64 RTKVHD64.sys Tue Jun 16 12:55:05 2015 (55800089)
fffff801`39400000 fffff801`3940f000   dump_diskdump dump_diskdump.sys Fri Oct 30 03:42:02 2015 (5632D8FA)
fffff801`39700000 fffff801`3971c000   dump_dumpfve dump_dumpfve.sys Fri Oct 30 03:40:02 2015 (5632D882)
fffff801`39720000 fffff801`39731000   HIDPARSE HIDPARSE.SYS Fri Oct 30 03:40:39 2015 (5632D8A7)
fffff801`39740000 fffff801`3976b000   usbccgp  usbccgp.sys  Fri Oct 30 03:39:08 2015 (5632D84C)
fffff801`39770000 fffff801`3977f000   rzendpt  rzendpt.sys  Tue Aug 11 13:13:46 2015 (55C9D8EA)
fffff801`39780000 fffff801`397a6000   usbaudio usbaudio.sys Fri Oct 30 03:38:42 2015 (5632D832)
fffff801`397b0000 fffff801`397c0000   kbdhid   kbdhid.sys   Fri Oct 30 03:39:42 2015 (5632D86E)
fffff801`397c0000 fffff801`397d3000   kbdclass kbdclass.sys Fri Oct 30 03:38:20 2015 (5632D81C)
fffff801`397e0000 fffff801`397ef000   mouhid   mouhid.sys   Fri Oct 30 03:39:03 2015 (5632D847)
fffff801`397f0000 fffff801`39823000   rzudd    rzudd.sys    Tue Aug 11 13:13:50 2015 (55C9D8EE)
fffff801`39830000 fffff801`39842000   mouclass mouclass.sys Fri Oct 30 03:37:57 2015 (5632D805)
fffff801`39860000 fffff801`3987d000   WudfPf   WudfPf.sys   Fri Oct 30 03:09:52 2015 (5632D170)
fffff801`39880000 fffff801`398a6000   luafv    luafv.sys    Fri Oct 30 03:34:43 2015 (5632D743)
fffff801`3a3a0000 fffff801`3a3ba000   HDAudBus HDAudBus.sys Fri Oct 30 03:37:21 2015 (5632D7E1)
fffff801`3a3c0000 fffff801`3a3d1000   hidusb   hidusb.sys   Fri Oct 30 03:41:44 2015 (5632D8E8)
fffff801`3a3e0000 fffff801`3a3f9000   storqosflt storqosflt.sys Fri Oct 30 03:37:39 2015 (5632D7F3)
fffff801`40540000 fffff801`41037000   nvlddmkm nvlddmkm.sys Sat Nov 14 06:44:20 2015 (5646CA34)
fffff801`41040000 fffff801`41050000   monitor  monitor.sys  Fri Oct 30 03:40:35 2015 (5632D8A3)
fffff801`41050000 fffff801`4105a000   NvStreamKms NvStreamKms.sys Fri Mar 18 22:26:05 2016 (56EC726D)
fffff801`41060000 fffff801`41094000   nvhda64v nvhda64v.sys Mon Sep 21 11:44:17 2015 (55FFD171)
fffff801`410f0000 fffff801`410fd000   rdpvideominiport rdpvideominiport.sys Fri Oct 30 03:10:08 2015 (5632D180)
fffff803`197fd000 fffff803`19808000   kd       kd.dll       Fri Oct 30 03:43:04 2015 (5632D938)
fffff803`1aa16000 fffff803`1aa89000   hal      hal.dll      Fri Oct 30 03:10:02 2015 (5632D17A)
fffff803`1aa89000 fffff803`1b255000   nt       ntkrnlmp.exe Fri Oct 30 03:15:45 2015 (5632D2D1)
fffff960`5ea00000 fffff960`5ed82000   win32kfull win32kfull.sys Fri Oct 30 03:16:22 2015 (5632D2F6)
fffff960`5ed90000 fffff960`5eef2000   win32kbase win32kbase.sys Fri Oct 30 03:27:57 2015 (5632D5AD)
fffff960`5ef10000 fffff960`5ef1a000   TSDDD    TSDDD.dll    unavailable (00000000)
fffff960`5f040000 fffff960`5f07c000   cdd      cdd.dll      Fri Oct 30 03:37:01 2015 (5632D7CD)
fffff960`5f9b0000 fffff960`5f9d3000   win32k   win32k.sys   Fri Oct 30 03:41:52 2015 (5632D8F0)
1 - 12 of 12 Posts
