BSOD crashes
471 9
I've oc'd my 7800gt to 508mhz and never had a problem. Games and 3D apps have been running fine. However yesterday I started getting BSOD crashes for no reason when I was using 3DS max. I couldn't even run FEAR either, it would crash as soon as it was loading. The GPU temp at that moment was 43 degrees. I dropped the OC to 495 and it worked fine again.
I didn't change anything yesterday so why would it suddenly crash like that? When playing a game the temp goes up to 64. Is the card damaged from heat, although I know 64 degrees isn't that much.
1 - 10 of 10 Posts
Isn't 3D Max a 3D designing program that's heavy on video cards, RAM, and the CPU?
If so, then that might be the reason. Your card wasn't stable in the first place, but sure it ran games fine. BUT as soon as heavy load started coming, the card couldn't handle it.
That happened when I was ocing. I was running the CPU fine overclocked, then as soon as some benchies or even [email protected] started running, the CPU couldn't handle it.
u meen 64 degrees celcius lol? because that is pretty hot but that shouldnt hurt and graphics card... you never know it could be possibly flawed make sure all your drivers etc are up to date... as usual and if you dont get the error after you backed down the clock then thats the problem and you solved it yourself.... It's weird how graphics cards act tho even if they are cool they can still mess up for some odd reason.. that probably no one knows about to well.
Well it ran 3DsMax and games fine before with the same OC settings. That's what I find weird, it was stable at these settings for the whole week. I was using 3DsMax for over 4hrs but the temps never went higher then 43 degrees celsius. FEAR would crash right away.
Driver's are up to date too.
Although it seems related to your Vcard--I would suggest thinking back if there are any other changes to your system--did you install any SW, update any drivers, add or recable any HDWR, or otherwise alter your system? The wierdest things can cause an IRQ issue or some other communication disorder in the OS...just a thought.
No changes in hardware, software (I only installed Doom3 since last week), I even ran MemTest86 thinking it was my RAM but it passed. So yeah it is a bit weird.
As for room temp, it's actually lower then last week too.
Discussion Starter · #9 ·
Originally Posted by PROBN4LYFE
strange events....hmmm
Strange events indeed.
I'll check tonight if it does it again, maybe it's one of those things that happen once and you'll never see again.
1 - 10 of 10 Posts
