BSOD During Crysis
1352 Views 31 Replies 11 Participants Last post by  IntelConvert
i was playing crysis for about an hour or so when game play started getting really choppy. i thought my vid card was heating up, so i minimized and turned up the fans manually, CPU temps were good. then i went back to the game, and about 5 mins later, i get a BSOD in the middle of the game.
the BSOD said a lot of crap about updating drivers and BIOS. (i just got the newest nvidia drivers for my 9800GT and i downloaded the F6 BIOS for my board when i built this computer) it also said that it had to dump the physical memory, did i run out of ram? i only have 2gb and i was playing with High settings and 2x AA. the game runs smooth to me, i only require 30 fps or so, and it did that until about 10 mins before the BSOD.
also, on CPUz, its reporting my memory at 480mhz, 2:1.. which is 940 mhz??? it should be running at 1066 mhz, it was the last time i checked. i think i dropped my OC from 3.33ghz to 3.0 at one point.. maybe i change something i didnt mean to? i want to do some work on my OC to get about 3.6ghz or so, stable, but thats another time
any ideas on what happened? or do i just not have enough ram?
i was playing on my sig rig if u need any info
1 - 20 of 32 Posts
I know it should not be done but try restoring the OC back to defaults and playing the game.
You stated that the CPU temps were good what about Memory and the GPU.
BTW how the hell did you get Crysis to run at 30FPS?
as above try dropping the OC's, or maybe just try runnign the game again. it might have been a one time thing
most benchmarks are done at Very High quality and high end video cards get 25-30 fps.. i was only running high details with 2x AA not 4x or 8x... so the 9800 GT does pretty well. 30 fps was an estimate for regular game play, during action scenes (blowing up a tank) it probably drops to 20 or so. and my GPU was at 64*C just prior to the BSOD and idk about ram temps, i dont have a program that reports those, if there is one... i have Gskill ram with heatspeaders on them and a decent exhaust fan, so all temps were good inside the case.
as for dropping the OC to stock.. ive run other games (they werent as demanding as crysis) on this OC.. never had a problem. i was thinking that having only 2gb of ram was the problem.
I can run Crysis like you with a bunch of programs running with no problems.
If it said something about updating drivers chances are it was a driver crash or something.
i just got the newest nvidia drivers after i installed the game.. i noticed some weird shading in the background and decided to update. after the update, the shading seemed to go away for the most part, but then i had this crash...
I think your probably running out of RAM, cause i by accident messed up MSCONFIG with vista so as i only was using 2.55 GB of ram for the longest time, and only in Crysis warhead i would get a complete system lock up for 3 seconds every 20 seconds of gameplay, sometimes the system just froze. Now i assume XP would get a BSOD in the same situation it isn't that had to believe, but try running some other tests to confirm. run Linpack or some CPU tester for ~6 hours, then your CPU is invinsible. Once we have determined the system is stable, the issue is the software not having enough system to use, then it may fill up all your RAM and drop the performance to a stand still causing a crash. This is just a theory, but it isn't a bad idea to run some tests for stablility
this is what i thought was happening. it seemed that once the game "filled my ram" the game started to slow down a lot in performance, this also happened to be during a very demanding part of the game (lots of stuff blowing up, running around a lot). then it just went to BSOD. running High details uses more memory than medium and low cause of the extra stuff it has for textures and so on.
i just set everything to default, excpet the ram is underclocked on accident.. i forgot my motherboard sets it at 800mhz by default, got to change the voltage and speed real quick, then ill give it another go.
^ speeds won't really help, it's just the fundamental fact that oyu lack the memory. Cause i tried that too
1100mhz 4-5-5-15 still caused the system to run like @ss. try running 2 threads of memtest and fill up your RAM beyond 100% for instance, set both at 1024mb and it should fill up everything, see if that causes a BSOD.
offtopic: 30fps in CRYSIS! then i realized xp, dx9 in the benchmark i pull like 65fps on veryhigh 1680x1050 dx9 and it all made sense
crysis wont let me select 'very high' as an option with my system specs.
i figred i was just out of ram..
it seems i cant get my RAM to run at 1066.. my ram just matches my CPU FSB.. its running 800 mhz now.. i can only change my RAM by changing the ram multiplier or changing teh CPU base clock speed... grrrrrrrr
anyway.. so if i just used medium settings, that uses less ram and therefor wont cause the BSOD? its my theory until i get more ram, any ideas on that working?
played on medium settings, went really well. i checked my physcial mem usage during game play every once in a while and i was nearing 900mb+ of mem used for crysis alone, i would imagine high details would use more mem than that. my free memory was only in the ~500mb range at some points. i can see how easily high details during very active times in the game could max out my ram.. seems like if i want to run high details, i need more ram..
running 32bit XP... buy 1gb or 2? i ahve a friend with 32bit xp and he has 4gb of ram recognized by the OS, and a vidcard that is atleast 256mb.. how is that??!? anyway i could run 4gb with my 32bit OS? im not looking for major upgrades at this point.
o and any ideas on how to get my ram at 1066 would be great.. i might just leave it at 800mhz and tighten timings a bit, should that give me roughly the same performance?
if i OC my video card at all crysis crashes. its just a really stressful game for video cards even though i can play any other game fine with it OCed.
IntelConvert. You can't run very high because your using XP, and Veryhigh uses DX10, which you do not have. My advice to you: get yourself Vista or 7 64 bit (XP sucks, ESPECIALLY for gaming) that way you can your 4gb of ram (get yourself 2 more gb). The 64 bit OS will run alot better trust me, i had 32 bit xp pro on renegade and it was horrid. and try running at 800 4-4-4-12, it should speed things up, and if intels are like AMD's, i would say try uping your NB clock, evern 200 mhz will greatly increase your system's "peppyness"
i forgot very high = DX10... lol. i know the 32bit sux cause i cant run 4gb, but i just bought a new car and i dont have the money for windows 7 right now.. i will be able to get it thru my school for $30 pretty soon, so i will do that and get 64bit. i realy like XP, its never failed me, but i will get windows 7 asap.
ill adjust my ram timings now, thanks a lot.
1) There's nothing wrong with gaming on XP. I've been doing it for 7+ years, and still do when I'm not playing the few DX10 games I own. XP 32-bit does NOT 'suck for gaming', like, at all. Even 2GB on XP 32-bit is enough for 99% of the games out there. Crysis may not be one of them though. Whether or not you should get 1 more stick or two kinda depends on what you see as being your next upgrade. I'd get two more 1GB sticks if I were you, and not worry about whether or not XP 'sees' all 4GB or not. It really doesn't matter, because 3GB is plenty enough ram for ANY game on XP. And if you have 4gb, then you're all ready for an upgrade to 64-bit Windows 7. Plus you make sure you stay in dual-channel mode that way.
2) It's not surprising Crysis would slow down over time running it on only 2GB. It 'should not' crash just because you've exceeded your 2GB, but it's logical it might slow down and get choppy as the page file gets used more and more. Note that there's a huge difference between 'should not' and 'would not' when it comes to computers. Also, the slowdowns could also have been due to where you were in the game. The earlier parts are much easier to run than the later parts (the ice and aliens put a big load on the gfx card).
3) PC games crash. Sometimes it just happens. I don't worry about it unless it keeps happening and there's no remotely logical reason for it.
4) The XP BSOD error message is very generic ... do not read anything into what it says. The only thing in that message that is remotely useful info is the name of the driver that crashed.
5) A 32-bit OS run on a board that supports Physical Address Extensions (with PAE enabled in the bios) will often appear to have 4GB available. This is the maximum amount of ram that a 32-bit OS can support. Theoretically some of this 4GB will be mapped to the video card memory addresses, thus reducing the 'available' ram for the system, but this may or may not show up as 'subtracted' from the 4GB, depending on where you look for it.
6) It would be logical to try reducing the overclock on the video card and seeing if the issue goes away. Crysis is a probably the ultimate 'stability tester' out there, and XP can for sure BSOD if your OC is a little too high ... which you might *only see* on Crysis because it's so demanding.
7) I am POSITIVE there's a way to get your memory to run at 1066 even if your FSB is at 800MHz with that board. There is a memory multiplier (aka strap) somewhere in your bios, you just have to find it and change it. This being said, due to the inherent latency introduced by simply having your memory controller in the northbridge (and a few other reasons), there's really VERY little (or no) performance difference between running your memory at 800MHz as opposed to 1066MHz on a 775 socket rig.
8) Mainly the reason that 1066 speed memory is nice to have is that it gives you more overclocking headroom when the memory is running 1-to-1 with your processor. You don't have to worry about cranking up the FSB to like 450MHz in order to overclock your cpu. When you do this, your memory ends up at 900MHz, which may be overclocked too far if you have 800MHz rated memory (bearing in mind that 1:1 is the lowest multiplier on 775 boards). This in turn would limit your cpu overclock ... which of course we do not want to see
+7 years, It's time to move on.
It's very probable that you ran out of ram, and i was getting BSOD's all the time with XP, heck, at stock clocks i had a hard time booting,
Convert: run memtest and fill up all your ram and see what happens
your RAM is most likely unstable, BSODs are always becuase of RAM if it was the CPU it would just reboot or freeze!
check your Mem for stability, run some OCCT in Large FFT test, and see what happens!
@ OP, your CPU could be bottlenecking really bad and crashing your system. Pentium + Crysis = Failure.
At this point I would bet that too high of a GPU OC is the issue here.
Nothing here is of use for diagnosing the OP's stability issues, and much of it is blatant misinformation.
XP and XP x64 are perfectly competent at gaming (and most other tasks), as long as DX10+ is not crucial. As a 9800GT is not really sufficent for DX10 Crysis, moving to Vista/7 will do nothing for his ability to play the game.
QFT.
720MHz on a 88/9800GT core is pretty high is the truth. Some chips will do it, and many will not. The first thing I'd try is stock gpu clocks just to see if the issue goes away. Then you at least have a starting point ...
BSOD's can ABSOLUTELY happen because of too high an overclock, either on the CPU or the GPU. I've personally seen it MANY MANY MANY times. Although crashing/freezing can certainly also happen
The horse-puckey continues to pile up on this thread. CPU-bottlenecks don't cause your system to crash. Yes, a pentium is not optimal for gaming (crysis especially), but it shouldn't cause the system to crash.
1 - 20 of 32 Posts
