Originally Posted by pipnasty ![]() I had the same problem before, try to google "how to enable AHCI in [insert your OS]" and you'll find your answer ![]() |
Originally Posted by gmpotu ![]() Found a fix. http://support.microsoft.com/kb/922976 Change that one little registry entry and windows should automatically recognize your chipset. Then before you restart you can install the Intel Matrix Storage Manager http://downloadcenter.intel.com/Deta...17882&lang=eng and it will update pretty much all the drivers etc. Now If I can just find out how to manually run TRIM |
