No need to worry but you should try to see what is wrong. Start with the ram and see if it is stable using Memtest. Then we will go from there.
You should have saved the '0x0000000' number. That would have solved it.Originally Posted by Hoops;13060590
Yeah, I think it might be the RAM. I just changed the settings last night from [Auto] to the 800MHz/1600 settings in BIOS (that's the factory clock for the G.Skills I have). Think that's it?
Wait...what's that? I don't remember seeing that number/option in the BIOS.Originally Posted by Track;13060614
