It was super fast and then restarted to Bios.do you remember the text message in the blue screen?
I appreciate that. I did run an SFC scan and got this:There is no need for alarm with a single BSOD thats just windows being windows
If it starts to happen more than once or it happens when you are doing something specific then it might be a drive or hardware issue
System is stock except for the XMP setting.sometimes this happen, even an update could cause this corrupted fiules, nothing to worry about too much.
If it happens very often,I would check out what is wrong.
Is the system overclocked?
Thanks for this!XMP is also an overclock, disable it and check with like tm5 with absolut config if it detects any errors without XMP
Memory Testing with TestMem5 TM5 with custom configs
Hello everybody I am just making a very light tutorial with a collection of custom config files and a DOWNLOAD LINK for TM5 v0.12 anta777 absolut config *Official* Intel DDR4 24/7 Memory Stability Thread None of the work is mine but it seems like a pretty good and fast testing appwww.overclock.net
CPU: AMD Ryzen 5 5600xWould be nice to know the system specs.
I have had this computer for a long time. This is my first Bsod.Ryzen and Corsair is not always a good match,what SKU does the RAM have and also version.
Ia this a new system?
Has it worked without any problems before or?
How do I run this thing. I double clicked the exe file but cant really tell if its working.XMP is also an overclock, disable it and check with like tm5 with absolut config if it detects any errors without XMP
It made me press ok on the memtest prompt for the administrative privileges like 6 times but it's running now.read the spoilers, you need too unpack it and open it with right mouse button with admin rights
click on load config,select the extreme 1 anta config in the bin file,from the tm5 directory
It is old but not 7 years old. The thing is, wouldn't I see issues in games if it was the PSU?Is your PSU about 7 years old? 3080 might be a pretty good load for a 600W of that age - ever monitor the 12 volt rail using HWINFO ?
Maybe your PSU isn't powerful enough for the 3080FE. Just a thought.CPU: AMD Ryzen 5 5600x
Mobo: B550i Aorus Pro AX
Memory: Corsair 3200 CL16
Video Card: 3080FE
PSU: Corsair SFX 600w
Cooler: EK AIO
