BSOD's constantly.
864 Views 19 Replies 12 Participants Last post by  Kirmie
I've been playing CoD: MW2 lately and I've been getting IRQ_NOT_LESS_THAN_OR_EQUAL problems...
Opened the crash dump in windbg and I get
Probably caused by : Unknown_Image ( ANALYSIS_INCONCLUSIVE )
1 - 20 of 20 Posts
Not sure, but it can be something about the RAM... try memtest?
It looks like you have hardware problems. Here is how to fix it: right click on my computer go to the hardware tab and look for device manager, if you have two or more components with problems try disabling them all or leave the one that is most important to you and report back
i think that error message is most of the time caused by an unstable OC, does it happen with stock settings ???
computer's at stock, non of the hardware has problems
Download and run Prime 95. Do a small FFT (for the CPU) first to see if it's a CPU related issue, then do a blended if the CPU checks out.
Also, what are your temps like?
Did you run memtest for a few hours? Make sure your hardware is seated completly.
I think you should turn up your Northbridge voltage and check you FSB
Do a thorough test on every piece of hardware, HDD, CPU, RAM, GFX (could be a problem with the driver) etc. Have you run CHKDSK, when my HDD got corrupt the IRQ_NOT_LESS_OR_EQUAL BSOD was the first sign I got. But it's most likely the RAM. 90% of the times it's the RAM. It could be CPU aswell, I got that BSOD when my CPU's temps went rambo.
Usually accompanies an unstable overclock. Always found it to be CPU-related.
I had a similar problem and from my research it seems like these are most often caused by driver problems. For example, when I upgraded my ATI drivers recently, I was getting these BSODs until I reverted the driver upgrade.
Did you happen to upgrade any drivers recently?
Also, this BSOD is one of the 10 most common ones, and it is sometimes quite difficult to figure out the problem, but testing RAM and GPU should be a good place to start.
i had the same issue, irql_not_less_or_equal, i did 20+ defrags, and wiped my drivers for a clean driver install and updated the bios, dont buy new ram till you have tried all other options, i bought new ram as the first step like i was told because everyone was %100 on it being a ram issue, and the same issues were present after i spent the money..
after that haven't had a blue screen since
ok temps are green. No problems on them all of them are all under 45
Going to post under this because want to ask a question and have it be noticed. Anyone else using an Asus Xonar DX with Windows 7? I was having problems with their drivers a while ago.
Creative is alway late with their software.
what does creative have to do with this?
RAM tested fine, CPU tested fine....
I'm at a loss....windows corruption?
ok this seems to be something to do with my video card......It might be getting to hot. I'm not sure but here's what happened recently
ic ^j=xB rtjorgenson
Error: Occlusion query failed after 16 tries
drawnSampleCount (-1) > sunSpriteSamples (256)
Received Splash 'buzzkill' in slot 0 for 1.500000 sec on localClientNum 0
deadaim ^j=xú@ FlyingPlookalak
[OCN]Black Magi ^==X„@ Kernel-Panic
[OCN]Black Magi ^==X„@ AdmiralVincent
*|SS|*Warlock ^j=xú@ [OCN]Black Magi
Playing smoke grenades at time 105802
Playing smoke grenades at time 105901
deadaim ^==øƒ@ Kernel-Panic
*|SS|*Warlock ^==øƒ@ FlyingPlookalak
deadaim ^j=xú@ rtjorgenson
[OCN]Black Magi ^==X„@ rtjorgenson
Playing smoke grenade at 119500 at ( 162.000000, -487.000000, -14.000000 )
Meany ^==øƒ@ Kernel-Panic
Received Splash 'sentry_pickup' in slot 0 for 2.500000 sec on localClientNum 0
Received Splash 'hijacker' in slot 0 for 2.500000 sec on localClientNum 0
deadaim ^j=xú@ AdmiralVincent
FlyingPlookalak ^j=Øú@ rtjorgenson
[OCN]Black Magi ^==X„@ *|SS|*Warlock
Received Splash 'revenge' in slot 0 for 1.500000 sec on localClientNum 0
Meany ^j=xú@ *|SS|*Warlock
AdmiralVincent ^j=xú@ Kernel-Panic
*|SS|*Warlock ^j=xú@ deadaim
FlyingPlookalak ^j=Øú@ [OCN]Black Magi
Playing smoke grenades at time 145004
Playing smoke grenades at time 145203
Playing smoke grenade at 148700 at ( -949.000000, 315.000000, -113.000000 )
*|SS|*Warlock ^j=xú@ AdmiralVincent
rtjorgenson ^j=¸4B FlyingPlookalak
deadaim ^j=xú@ *|SS|*Warlock
Kernel-Panic ^j=8`B Meany
Direct3DDevice9::Present failed: n/a
Got that while play CoD:MW2
The game started artifacting terrbily before it flat gave out. I'm thinking heat might be an issue since there really isn't any airflow in my case due to the watercooling.....so I need ideas.......there's a 120mm fan on the back of my case and a huge hole that fits my radiator and 3 120mms on top....any ideas how to increase cooling?
What about your HDD?
EDIT: Sorry, I didn't see your post with the GPU. I don't know much about GFX cards so I don't think my answer will help you, but I'll try. Could it be the GPU cooler that has started fail? And since you don't really have any airflow in your case, then it might be an idea to install some fans.. Even though I find it unlikely to be the airflow as you would've noticed it from the beginning.
Have you tried using a program like CPUID Hardware Monitor to see what your temps are during load?
Can you move your graphics card to the other slot if you haven't reseated it already? As for cooling are those all blowing out? If so do you have any bringing in air or at least vents that allow the air in? If not the adding a way for air to get in, other than forcing its way through cracks, would help you control the flow of air in your case and lower your temps. With your current setup you would likely want to bring in air from the area around the bottom to the bottom front corner I believe. Maybe try testing the game with your case open to see if the fresh air helps? Oh, and its getting colder out where I live so maybe the heat kicked on and you are too close to a vent?
What did you use to test your GPU? I find that Furmark heats the living crap out of GPU's so that should give you a good idea. Anyways, I would say reseat the GPU, test in another slot, maybe try a new power connector (I'm assuming that thing needs more power than the slot can provide, if not then wow). Heck, maybe it is just a driver issue if it only happens in one game. There is also the possibility of issues being caused by the bridge but at stock levels I find that very doubtful.
1 - 20 of 20 Posts
