1 - 3 of 3 Posts
Atm im looking to get a really cheap athlon 64 3000+ or something. Basicaly the processor isnt a problem it will be socket 939 and i was hoping someone could help me find a budget motherboard that has and agp socket - and pci / agp lock. Im thinking less than £50 it doesnt need to have great overclockablity as ill be using stock hsf on that pc anyway.<br><br>
Thanks<br>
Squeeky
Asrock 939Dual-SATA2 PCI-E and AGP<br><a href="http://www.overclockers.co.uk/acatalog/Online_Catalogue_Others__Asrock__BFG___Foxconn__174.html" target="_blank">http://www.overclockers.co.uk/acatal...conn__174.html</a><br>
the 3rd one on the page...£46.99
Reactions: Squeeky
I second that.....the Asrock is a nice board, average OC'er if you are thinking of doing it aswell<img src="/images/smilies/thumb.gif" border="0" alt="" title="Thumb" class="inlineimg" /> <br />
<br />
Although let me advise you to get a 3700. They are next to nothing nowadays and if you can't afford it, then get the 3000. But they 3700 are amazing OC'ers and well worth the pennies. Good luck Iced
Reactions: Squeeky
1 - 3 of 3 Posts
