1 - 4 of 4 Posts
I have an ANCIENT s754 AMD build so it is definitely time to upgrade. I'd like to be able to game a little bit such as Microsoft flight sim X maxed out settings. I'm on a budget of $450, can anyone help me out to achieve this build? I can user current OS and 500gb HDD and have a 450 power supply if that'll suffice. I can even use current case to save money. I would like to do mild overclocking nothing crazy. Would prefer nvidia video card as well.
Thanks in advance!
So you need CPU, motherboard, RAM, and GPU. Let's see, you don't really need a lot of GPU power, you should be fine on HD4000. Overclocking a $450 build will be tough, considering you need a 3570K at the lowest end for unlocked processors.
CPU: Intel i5-3570K http://www.microcenter.com/product/388577/Core_i5_3570K_34GHz_LGA_1155_Processor
Motherboard: ASUS P8Z77-V http://www.amazon.com/dp/B007G51UWY/?tag=pcpapi-20
RAM: Samsung 4GB 1600mHz http://www.macconnection.com/IPA/Shop/Product/Detail.htm?sku=13088531&SourceID=k275760&cm_mmc=GAN-_-PC%20Part%20Picker-_-Primary%20Banner-_-k275760&clickid=0004d5f2d40a9bbc0ae01443ff006ca6
For a rig on that budget, I would rather go for a more budget oriented build. Buying a $180 motherboard on a $450 budget seems like a waste.
Here is what I would do:
CPU: i3 3220:
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116775
Motherboard: ASRock z77 Extreme4:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157293
Ram: Samsung Ram that KeyboardXpert mentioned
GPU: as far as graphics are concerned I would go for an AMD 7850 right now, but If you can't fit it in your budget, I would get a GTX 650 ti
7850: http://www.newegg.com/Product/Product.aspx?Item=N82E16814202004
650 ti: http://www.newegg.com/Product/Product.aspx?Item=N82E16814130839
CPU: i3 3220:
He plays Flight Sim X, he doesn't need discrete graphics. I played Minecraft with a 256x HD texturepack and GLSL Shaders on the HD4000. And why would he buy an i3 and then an Extreme4? OP, can we get a full list of the programs and games you use frequently?
1 - 4 of 4 Posts
