1 - 10 of 10 Posts
Originally Posted by YiffyGriffy
Sound Blaster Audigy. Don't even really need to get an Audigy 2 since they're almost the same thing, and the average person wouldn't be able to tell a difference.
link? there are quite a few audigy's dont wanna mess up and get the wrong one. btw, wat about the audigy "gamer"?
The only difference between the first and the second is the second allow for 96KHz recording... unless you're going to do any recording it doesn't matter. And unless you are using 7.1 speakers, why do you need 7.1 channel sound card?
Why wouldnt he want a 7.1 channel soundcard should be the question, 7.1 cards still support 5.1, 7.1 cards just have extra jacks for the 7.1 standard, buying 7.1 is the smart thing to do as it means he won't have to go out and blow another $90+ on a soundcard anytime soon.
indeed....
1 - 10 of 10 Posts
