Budget i5 gaming.
1033 Views 10 Replies 5 Participants Last post by  judoreflex
This build will allow you to play games at mid. to max. settings at a monitor resolution of 1920x1080 or less
1 - 11 of 11 Posts
Okay.
What exactly are you asking?
I built an i5 gaming rig for less than $800 that is more than powerful enough to game at that resolution.
Originally Posted by judoreflex View Post
Gamer: $1,087.90
•CPU: Intel Core i5 750 Lynnfield 2.66GHz LGA 1156 95W Quad-Core Processor Model BX80605I5750 - Retail
•MOBO: GIGABYTE GA-P55M-UD4 LGA 1156 Intel P55 Micro ATX Intel Motherboard - Retail
•RAM: G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL7D-4GBRH - Retail
•HSF: COOLER MASTER Intel Core i5 & Intel Core i7 compatible RR-B10-212P-GP 120mm "heatpipe direct contact" Long life sleeve CPU ... - Retail
•HDD: SAMSUNG Spinpoint F3 HD502HJ 500GB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive - OEM
•PSU: CORSAIR CMPSU-750TX 750W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Compatible with Core i7 Power ... - Retail
•GPU: XFX HD-585A-ZNFC Radeon HD 5850 (Cypress Pro) 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card w/ATI Eyefinity - Retail
•DVD: SAMSUNG Black 22X DVD Burner Black SATA Model SH-S223B - OEM
•Case: COOLER MASTER HAF 922 RC-922M-KKN1-GP Black Steel + Plastic and Mesh Bezel ATX Mid Tower Computer Case - Retail
•Thermal Compound: Arctic Silver 5 Thermal Compound - OEM
This build will allow you to play games at mid. to max. settings at a monitor resolution of 1900x1200
The only thing i would argue with would be the PSU, if there isn't going to be CF a 500w would be just fine
Otherwise it looks like it is going to be a good build and please make a build log for all the see
Good job?
witch one do you recomend?
looks okay in my book. If you're overclocking, make sure that board has a lotus socket. Foxconn sockets were poorly designed for the p55 platform and burn out. Gigabyte uses both brands.
thanks.
1 - 11 of 11 Posts
