1 - 12 of 12 Posts
My friend is looking to get a new pc, and he is going to have about 600$ to spend. He just need a computer, no mouse keyboard or monitor. I just wanted some suggestions on what would be good, please show links. Thanks in advance.
Dell.com jk Chozart will find something
$600 budget, perhaps telling us what it will be used for so the config can be considered.<br />
<br />
Will he be needing HDD, PS, Case, CD/DVD-ROM too?
<a href="http://www.Cyberpowerpc.com" target="_blank">www.Cyberpowerpc.com</a> for now
Is he parting out the Dell to build a new on or just buils from a new case and up?<br />
Will he be OCing?
Discussion Starter #7
well the most he would keep would probably be the case hd and dvd drive, he doesnt know how to overclock, but i could help him a little bit
The cas may be a bit of an issue, check out the connections for the on/off, power on light, etc... they are usually a module that can be difficult to get to work on an aftermarket MB.
3700+<br>
Biostar 6100<br>
1 gig g.skill<br>
1 antec truepower<br>
7600gt<br>
stock heatsink<br>
cheap-o-case
MB AM2 $72<br><a href="http://www.newegg.com/Product/Product.asp?Item=N82E16813138028" target="_blank">http://www.newegg.com/Product/Produc...82E16813138028</a><br>
CPU Orleans 3200+ good OCer which should hit 2700MHz or higher $79<br>
But you would probably need a better HSF, but only for about over 2600MHz OCs<br><a href="http://www.newegg.com/Product/Product.asp?Item=N82E16819103637" target="_blank">http://www.newegg.com/Product/Produc...82E16819103637</a><br>
RAM DDR2 800 2x1G $220<br><a href="http://www.newegg.com/Product/Product.asp?Item=N82E16820231098" target="_blank">http://www.newegg.com/Product/Produc...82E16820231098</a><br>
7900GS vid card $190<br><a href="http://www.newegg.com/Product/Product.asp?Item=N82E16814186003" target="_blank">http://www.newegg.com/Product/Produc...82E16814186003</a><br><br><br>
That's considering he is using his CD/DVD-ROM, HDD, Floppy and case<br>
He will probably need at least a different PS! or Case?PS combo but about the only good case/PS is Antec.
i like dukes finds, but a case and psu is a must. I don't even know if you can hook up a non dell mobo to the dell case? I thought the screw patterns are different? Anyways, a 450 watt power supply would be good enough, I would suggest antec. Good luck with the build. Mike
1 - 12 of 12 Posts
