Rig Purpose: Decoding, Hosting, Benching, Gaming, Hobby
Hardware
CPU: Intel Core I7 3820 3.6Ghz
Motherboard: Asus P9X79 WS X79 LGA 2011
RAM: 2x Mushkin 4x4gb 1600mhz 8-8-8-24 1.5v
GPU: SLI GTX 680
PSU: Corsair AX1200
HDDs: 4x Samsung Spinpoint F3 1tb
SSDs: 2x Patriot Pyro SE 60gb
Case: Case Labs STH-10
Watercooling:
CPU Waterblock: EK-Supreme HF
GPU Waterblock: Undecided
Radiator: XSPC EX480 and RX360
Pump: 2x MCP355
Reservoir: EK 250 or Custom
Other:
Case Fans: Scythe Gentle Typhoon 1150rpm
Radiator Fans: Yate Loon Medium speed
Fan Controller: G-Vans FC9
**Updates**
4-9-2012
Just places multiple orders for cable, fans and radiators as well as miscellaneous stuff.
3-15-2012
Got my 2nd SSD back from RMA. Updates & pics will be updated later today once I get off work.
3-7-2012
I was able to get the mushkin ram to run stable with a BIOS update, so those wont be RMA'ed.
3-6-2012
Got my parts in but had to do a RMA on one of the SSD's because the pcb wasn't mounted correctly inside the case. I also had to RMA the ram because it wasn't stable and wouldn't post 1/2 the time above 1200mhz @ 1.65 and stock is 1600mhz @ 1.5v.
3-1-2012
All hardware but the gpu has been ordered.
Watercooling will be waiting tell nvidia kepler is out.
Im not sure if this cpu will be long term or not, depends on how well IB does.
