1 - 20 of 164 Posts
I had initially posted my build log over <a class="bbcode_url" href="http://www.overclock.net/t/1600242/build-log-arcane-sanctum">here</a>, but this might be a better spot.<br><br>
This will be my second water cooled PC. I've been raiding as a <span style="color:#69CCF0;">mage</span> in WoW since Burning Crusade, which has inspired the theme for <b><span style="color:#69CCF0;">Arcane Sanctum</span></b>.<br><br><span style="font-size:24px;"><b><span style="color:#69CCF0;">Arcane Sanctum</span></b></span><br><span style="font-size:16px;"><b>Design Considerations</b></span><br><b>Colour Scheme</b>, I want the flexibility to adjust my colour scheme with my fluid selections and/or the RGB lights. Over the two years I've had my Primo build I've changed the colour scheme many times, and having the red/black on my hardware has restricted the combinations I've been able to set. For this reason, I'm setting a conservative understated colour theme with my hardware that will be black/gunmetal/white.<br><br><b>Dust Control</b>, I plan to filter all of my intake fans with something simple to clean, and maintain positive pressure (with empirically tested profiles). I haven't yet decided how I will filter the fans, but as soon as I have received the Caselabs case I should be able to determine how simple removing the front radiator panel to access fan-mounted filters would be, and go from there.<br><br><b>Filling</b>, I had a single port top with my Primo build and found I would simply remove the cap and tilt the reservoir out of my case to pour directly from a gallon jug of distilled water to flush/fill. With glass tubing this won't be possible, and so I've opted for a three-port top to simplify filling the loops.<br><br><b>Draining</b>, I will try out the Bitspower Exhaust fittings on the top ports of my 480mm top mounted radiators. These will be accessible with the top cover removed. If they don't work out as I'd like, I may install 90 degree fittings with Quick Disconnects and a length of tubing for atmospheric pressure to the top of the loop when draining. Drain valves will be installed at the bottom of the loop (the drain ports on the Alphacool 360s).<br><br><b>Tubing</b>, 90 deg perpendicular runs only, with the exception of the memory to the monoblock (too crowded to be clean otherwise). I want to show off the glass tubing, but not be too crowded.<br><br><b>Dual Loops</b>, One loop for the GPUs, and a second for the Monoblock & memory.<br><br><br><b><span style="font-size:16px;">PC Components</span></b> <b><span style="color:#69CCF0;">received</span></b><br><b>Case</b> - Caselabs Magnum THW10<br><b>CPU</b> - Intel x99 Broadwell-E, i7 6850k 4.6GHz (pre-binned by Silicon Lottery)<br><b>Memory</b> - 8x4GB DDR4-19200 (2400 MHz) G Skill Ripjaws 4<br><b>GPU</b> - 2x ASUS 1080 Founders Edition<br><b>PSU</b> - Corsair AX1500i<br><b>OS Drive</b> - Samsung 950 PRO M.2 NVME 512GB<br><b>Motherboard</b> - Asus Rampage V Edition 10<br><b>Monitors</b> - Desk Mounted 3x2 setup. 3x ROG Swift PG27AQs in Surround (lower level), 3x Dell U2412Ms (upper level)<br><b>Monitor Stand</b> - WSGF Ultimate, I already had a Wall-Mounted 1-over-3, so I only needed the XL upgrade kit for the 27" ROGs<br><b>Cables</b>, custom from IceMods<br><br><b><span style="font-size:16px;">Water Cooling Components</span></b> <b><span style="color:#69CCF0;">received</span></b><br><b>CPU or Motherboard Monoblock</b> - EK Plexi/Nickel RVE10 Monoblock<br><b>GPU Blocks</b> - EK Plexi/Nickel (transparent), Nickel backplates<br><b>Memory Blocks</b> - EK Plexi/Nickel (transparent) Monarchs with Nickel heatspreaders<br><b>Pumps</b> - Alphacool VPP655-PWM, custom sleeved cables<br><b>Pump Upgrades</b> - Bitspower D5 MOD TOP<br><b>Pump Upgrades</b> - Bitspower D5 / MCP655 Mod Kit V2 - Black Sparkle Finish<br><b>Reservoirs</b> - Bitspower Dual / Single D5 Top Upgrade Kit 250 (I may have to adjust the tube size as we start building, also have two 300 tubes on hand)<br><b>Reservoir Upgrades</b> - Bitspower Premium Female G1/4" Black Sparkle Aqua-Pipe II Fitting<br><b>Reservoir Upgrades</b> - Bitspower Z-CAP II With G1/4" x3<br><b>Reservoir Mounting</b> - Singularity Computers Ethereal Dual v2 (Black)<br><b>Radiators</b> - Dual top mounted Alphacool NexXxoS UT60 Full Copper 480mm. I opted for 480mm over 560mm for flexibility with filling, draining, and fan control. More on this later.<br><b>Radiators</b> - Dual vertical mounted Alphacool NexXxoS UT60 Full Copper 360mm.<br><b>Fans</b> - 21x DarkSide Gentle Typhoon Performance Radiator Fan (550-1850rpm) 58cfm - Black Edition PWM, all custom sleeved<br><b>Fan PCB</b> - 5x ModMyToys 4-Pin PWM Power Distribution PCB - 8-Way Block <b>UPDATE</b>: I will be replacing these with SPLITTY9s as they report inconsistent RPM speeds back to my AQ6.<br><br><b>Fittings</b>, All Bitspower Black Sparkle unless otherwise noted <b><span style="color:#69CCF0;">received</span></b><br>
G1/4 Enhanced Multi-Link Adapter - 12mm OD Rigid Tube<br>
Shutoff Ball Valves (x4)<br>
5/8/10/20/25/30/40mm Spacers<br>
Male/Male Adaptors<br>
90 Degree Rotary Adaptor Male/Female<br>
90 Degree with Dual Inner G1/4" Extender<br>
3/8" - 1/2" Straight Compression Fittings (Black Nickel for rear compartment)<br>
Temperature Sensor Stop Fitting<br>
"T" Fitting<br>
Air-Exhaust Fitting<br><br>
EK-AF Pass Through G1/4 - Black Nickel (I didn't like the look of the Bitspower pass through fittings)<br><br><b>Tubing</b> <b><span style="color:#69CCF0;">received</span></b><br>
Ultra Clear 3/8-1/2" Tubing<br>
None Chamfer PETG Link Tube OD 12mm (initially doing the loop in PETG before making cuts with the Mayhems Glass)<br>
Mayhems Glass 12mm Tubing<br><b>Update</b>: The glass cutting failed. The tool I had to score the glass walks if there isn't enough pressure on the glass, but shatters it if there's too much. The margin for error is incredibly small and I'm not confident I could make the number of cuts necessary to complete my loop. Sticking with the PETG for now.<br><br><b>Flair/Accessories</b> <b><span style="color:#69CCF0;">received</span></b><br>
Aquacomputer Aquaero 6 XT USB Fan Controller (/w replacement Blue LED front cover)<br>
Aquacomputer Passive Heatsink for Aquaero 6 - Black<br>
Aquacomputer Front Faceplate for Aquaero 5/6 XT Aluminium - Black<br>
Aquacomputer Mounting Plate for Poweradjust 2 USB - Black Anodized Aluminium<br>
Aquacomputer Poweradjust 3 USB - Ultra-Series (x2)<br>
Aquacomputer Passive Heat Sink for Poweradjust 3 - Black (x2)<br>
Aquacomputer farbwerk USB, aquabus version<br>
Aquacomputer RGB LED Strip, IP67, Black, Length 50cm<br>
Bitspower Flow Sensor (BP-FS-CLBKBK) - Clear/Black/Black Sparkle<br>
Bitspower X-Station Power-Extension II - Male Version - UV<br><br><br>
If there's anything in particular you would like to see as this project progresses, please let me know.
Discussion Starter #2
And we're done!!!<br><br><a class="H-lightbox-open" href="http://www.overclock.net/content/type/61/id/2858953/"><img alt="" class="lightbox-enabled" data-id="2858953" data-type="61" src="http://www.overclock.net/content/type/61/id/2858953/width/350/height/700/flags/LL" style="; width: 350px; height: 197px"></a><br><a class="H-lightbox-open" href="http://www.overclock.net/content/type/61/id/2858954/"><img alt="" class="lightbox-enabled" data-id="2858954" data-type="61" src="http://www.overclock.net/content/type/61/id/2858954/width/350/height/700/flags/LL" style="; width: 350px; height: 197px"></a><br><a class="H-lightbox-open" href="http://www.overclock.net/content/type/61/id/2858955/"><img alt="" class="lightbox-enabled" data-id="2858955" data-type="61" src="http://www.overclock.net/content/type/61/id/2858955/width/350/height/700/flags/LL" style="; width: 350px; height: 197px"></a><br><a class="H-lightbox-open" href="http://www.overclock.net/content/type/61/id/2858956/"><img alt="" class="lightbox-enabled" data-id="2858956" data-type="61" src="http://www.overclock.net/content/type/61/id/2858956/width/350/height/700/flags/LL" style="; width: 350px; height: 197px"></a><br><a class="H-lightbox-open" href="http://www.overclock.net/content/type/61/id/2858957/"><img alt="" class="lightbox-enabled" data-id="2858957" data-type="61" src="http://www.overclock.net/content/type/61/id/2858957/width/350/height/700/flags/LL" style="; width: 350px; height: 197px"></a><br><a class="H-lightbox-open" href="http://www.overclock.net/content/type/61/id/2858958/"><img alt="" class="lightbox-enabled" data-id="2858958" data-type="61" src="http://www.overclock.net/content/type/61/id/2858958/width/350/height/700/flags/LL" style="; width: 350px; height: 197px"></a><br><a class="H-lightbox-open" href="http://www.overclock.net/content/type/61/id/2858959/"><img alt="" class="lightbox-enabled" data-id="2858959" data-type="61" src="http://www.overclock.net/content/type/61/id/2858959/width/350/height/700/flags/LL" style="; width: 350px; height: 197px"></a><br><a class="H-lightbox-open" href="http://www.overclock.net/content/type/61/id/2858960/"><img alt="" class="lightbox-enabled" data-id="2858960" data-type="61" src="http://www.overclock.net/content/type/61/id/2858960/width/350/height/700/flags/LL" style="; width: 350px; height: 197px"></a><br><a class="H-lightbox-open" href="http://www.overclock.net/content/type/61/id/2858961/"><img alt="" class="lightbox-enabled" data-id="2858961" data-type="61" src="http://www.overclock.net/content/type/61/id/2858961/width/350/height/700/flags/LL" style="; width: 350px; height: 197px"></a><br><a class="H-lightbox-open" href="http://www.overclock.net/content/type/61/id/2858962/"><img alt="" class="lightbox-enabled" data-id="2858962" data-type="61" src="http://www.overclock.net/content/type/61/id/2858962/width/350/height/700/flags/LL" style="; width: 350px; height: 197px"></a><br><a class="H-lightbox-open" href="http://www.overclock.net/content/type/61/id/2858963/"><img alt="" class="lightbox-enabled" data-id="2858963" data-type="61" src="http://www.overclock.net/content/type/61/id/2858963/width/350/height/700/flags/LL" style="; width: 350px; height: 197px"></a><br><a class="H-lightbox-open" href="http://www.overclock.net/content/type/61/id/2858964/"><img alt="" class="lightbox-enabled" data-id="2858964" data-type="61" src="http://www.overclock.net/content/type/61/id/2858964/width/350/height/700/flags/LL" style="; width: 350px; height: 197px"></a><br><a class="H-lightbox-open" href="http://www.overclock.net/content/type/61/id/2858965/"><img alt="" class="lightbox-enabled" data-id="2858965" data-type="61" src="http://www.overclock.net/content/type/61/id/2858965/width/350/height/700/flags/LL" style="; width: 350px; height: 197px"></a><br><a class="H-lightbox-open" href="http://www.overclock.net/content/type/61/id/2858966/"><img alt="" class="lightbox-enabled" data-id="2858966" data-type="61" src="http://www.overclock.net/content/type/61/id/2858966/width/350/height/700/flags/LL" style="; width: 350px; height: 197px"></a>
Way to Go Spirillum, this guy is so awesome! <img alt="biggrin.gif" class="bbcode_smiley" src="http://files.overclock.net/images/smilies/biggrin.gif"> +rep for grand decision making abilities. <img alt="tongue.gif" class="bbcode_smiley" src="http://files.overclock.net/images/smilies/tongue.gif"><br><br><br>
So happy you moved your build log over here, as to include many more great CaseLabs people who may enjoy your glorious build.<br><br><span style="font-size:10px;"><br><br>
Psssst: his hardware is off the charts - high end amazing top shelf. <img alt="wink.gif" class="bbcode_smiley" src="http://files.overclock.net/images/smilies/wink.gif"></span>
Discussion Starter #4
<div class="quote-container" data-huddler-embed="/t/1603758/build-log-arcane-sanctum-magnum-thw10#post_25280879" data-huddler-embed-placeholder="false"><span>Quote:</span>
<div class="quote-block">Originally Posted by <strong>iBruce</strong> <a href="/t/1603758/build-log-arcane-sanctum-magnum-thw10#post_25280879"><img alt="View Post" class="inlineimg" src="/img/forum/go_quote.gif"></a><br><br>
Psssst: his hardware is off the charts - high end amazing top shelf. <img alt="wink.gif" class="bbcode_smiley" src="http://files.overclock.net/images/smilies/wink.gif"></span></div>
</div>
<br>
Thanks for the warm welcome!
In for the sub train, let's show this thread some love! <img alt="wubsmiley.gif" class="bbcode_smiley" src="http://files.overclock.net/images/smilies/wubsmiley.gif">
Discussion Starter #6
Just waiting for that Rampage motherboard (that should be arriving any day now).<br><br><a class="H-lightbox-open" href="http://www.overclock.net/content/type/61/id/2814226/"><img alt="" class="lightbox-enabled" data-id="2814226" data-type="61" src="http://www.overclock.net/content/type/61/id/2814226/width/350/height/700/flags/LL" style="; width: 350px; height: 197px"></a><br><br>
A quick warning about the Nickel Monarch memory heatspreaders: they scratch very easily, so I'm leaving them wrapped in foam until they're ready to go into the mobo. One side of one of my modules has a couple of noticable scratches on the one surface, just from having it on my desk and moving it around a bit as I was trying to line up the heatspreaders on the memory with the previous sticks.
Discussion Starter #7
I finished benchmarking my current build.<br><br>
I ran:<br><br>
Fire Strike Extreme<br>
Fire Strike Ultra<br><br>
World of Warcraft: Warlords of Draenor<br>
Doom<br><br><br>
I also looped Fire Strike Extreme to stress test and record temperatures/voltages etc to compare against Arcane Sanctum.<br><br><br><b>World of Warcraft and GPU Overclocking</b><br>
There are great benefits to be had by overclocking your GPU when you play on higher resolutions. These were my results comparing my OCd setup to stock.<br><br><a class="H-lightbox-open" href="http://www.overclock.net/content/type/61/id/2814702/"><img alt="" class="lightbox-enabled" data-id="2814702" data-type="61" src="http://www.overclock.net/content/type/61/id/2814702/width/350/height/700/flags/LL" style="; width: 350px; height: 207px"></a><br><br><br>
Raising the average fps from 63 to 72 makes everything feel much smoother. On my previous build I had to tweak graphics settings to maintain 60 fps. With this one, it was as simple as some tweaking.
Spril, I just got my RVE10 replacement today. Thank goodness it was not another engi sample. Hopefully yours comes right quick <img alt="thumb.gif" class="bbcode_smiley" src="http://files.overclock.net/images/smilies/thumb.gif">
The build is big. I am here. <img alt="thumb.gif" class="bbcode_smiley" src="http://files.overclock.net/images/smilies/thumb.gif">
Discussion Starter #10
Today EK released their much anticipated (at least, it was for me) <a class="bbcode_url" href="https://www.ekwb.com/news/ek-releases-msi-gtx-1080-tf6-full-cover-water-block/" target="_blank"><span style="text-decoration:underline;">water block</span></a> for the MSI 1080 Gaming X, of which I had purchased two. To put it bluntly, it's the worst looking EK block I've ever seen. Liquid covering nickel plate? Only partial PCB coverage? No backplates available at launch? Costs <i>more</i> than the Founders Edition block? I can only speculate that this farce of a product was hastily shambled together in an effort to differentiate from the Sea Hawk EK X. Aesthetically, it is excrement.<br><br>
Luckily for me, my Rampage V Edition 10 has been delayed (though it's expected on Monday) and I hadn't opened the boxes or removed the factory shrinkwrap from the MSI cards. I exchanged them for Founders Editions and ordered GPU blocks/nickel backplates from EK.<br><br><a class="H-lightbox-open" href="http://www.overclock.net/content/type/61/id/2816923/"><img alt="" class="lightbox-enabled" data-id="2816923" data-type="61" src="http://www.overclock.net/content/type/61/id/2816923/width/350/height/700/flags/LL" style="; width: 350px; height: 197px"></a><br><a class="H-lightbox-open" href="http://www.overclock.net/content/type/61/id/2816925/"><img alt="" class="lightbox-enabled" data-id="2816925" data-type="61" src="http://www.overclock.net/content/type/61/id/2816925/width/350/height/700/flags/LL" style="; width: 350px; height: 197px"></a><br><br>
I also received my package from Icemodz. What hasn't been said about the quality? My photo absolutely will not do them justice, and I'm afraid we'll have to see these in the build to really appreciate them. As far as cables go, these make me want to feature them in my build instead of hide them. Truly exceptional work!!<br><br><a class="H-lightbox-open" href="http://www.overclock.net/content/type/61/id/2816926/"><img alt="" class="lightbox-enabled" data-id="2816926" data-type="61" src="http://www.overclock.net/content/type/61/id/2816926/width/350/height/700/flags/LL" style="; width: 350px; height: 197px"></a>
<a class="H-lightbox-open" href="http://www.overclock.net/content/type/61/id/2462636/"><img alt="" class="lightbox-enabled" data-id="2462636" data-type="61" src="http://www.overclock.net/content/type/61/id/2462636/width/350/height/700/flags/LL" style="; width: 350px; height: 214px"></a>
Discussion Starter #14
It's here.<br><br><a class="H-lightbox-open" href="http://www.overclock.net/content/type/61/id/2818213/"><img alt="" class="lightbox-enabled" data-id="2818213" data-type="61" src="http://www.overclock.net/content/type/61/id/2818213/width/350/height/700/flags/LL" style="; width: 350px; height: 197px"></a>
Nice, I love QCK pads, been using them since I was a teen fragging noobs in counter strike from waaaaay back in the day <img alt="thumb.gif" class="bbcode_smiley" src="http://files.overclock.net/images/smilies/thumb.gif">
<div class="quote-container" data-huddler-embed="/t/1603758/build-log-arcane-sanctum-magnum-thw10/10#post_25307574" data-huddler-embed-placeholder="false"><span>Quote:</span>
<div class="quote-block">Originally Posted by <strong>Spirillum</strong> <a href="/t/1603758/build-log-arcane-sanctum-magnum-thw10/10#post_25307574"><img alt="View Post" class="inlineimg" src="/img/forum/go_quote.gif"></a><br><br>
It's here.<br><br><a class="H-lightbox-open" href="http://www.overclock.net/content/type/61/id/2818213/"><img alt="" class="lightbox-enabled" data-id="2818213" data-type="61" src="http://www.overclock.net/content/type/61/id/2818213/width/350/height/700/flags/LL" style="; width: 350px; height: 197px"></a></div>
</div>
<br>
And he doesn't even share with his brothers in the Millennium thread. <img alt="sad-smiley-002.gif" class="bbcode_smiley" src="http://files.overclock.net/images/smilies/sad-smiley-002.gif">
Discussion Starter #17
<div class="quote-container" data-huddler-embed="/t/1603758/build-log-arcane-sanctum-magnum-thw10/10#post_25307820" data-huddler-embed-placeholder="false"><span>Quote:</span>
<div class="quote-block">Originally Posted by <strong>sexpot</strong> <a href="/t/1603758/build-log-arcane-sanctum-magnum-thw10/10#post_25307820"><img alt="View Post" class="inlineimg" src="/img/forum/go_quote.gif"></a><br><br>
Nice, I love QCK pads, been using them since I was a teen fragging noobs in counter strike from waaaaay back in the day <img alt="thumb.gif" class="bbcode_smiley" src="http://files.overclock.net/images/smilies/thumb.gif"></div>
</div>
<br>
My first foray into a large pad. I've used all manner of Razer mousepads in the past but they tend to wear out on me. Most recently I used the ironclad but I found after a while you start to get friction between the mouse and the pad, with some microstuttering of the cursor. Not great. Back to fabric!<br><div class="quote-container" data-huddler-embed="/t/1603758/build-log-arcane-sanctum-magnum-thw10/10#post_25307872" data-huddler-embed-placeholder="false"><span>Quote:</span>
<div class="quote-block">Originally Posted by <strong>iBruce</strong> <a href="/t/1603758/build-log-arcane-sanctum-magnum-thw10/10#post_25307872"><img alt="View Post" class="inlineimg" src="/img/forum/go_quote.gif"></a><br><br>
And he doesn't even share with his brothers in the Millennium thread. <img alt="sad-smiley-002.gif" class="bbcode_smiley" src="http://files.overclock.net/images/smilies/sad-smiley-002.gif"></div>
</div>
<br>
I didn't want to spam with the photos, but I posted that it showed up!
<div class="quote-container" data-huddler-embed="/t/1603758/build-log-arcane-sanctum-magnum-thw10/10#post_25307936" data-huddler-embed-placeholder="false"><span>Quote:</span>
<div class="quote-block">Originally Posted by <strong>Spirillum</strong> <a href="/t/1603758/build-log-arcane-sanctum-magnum-thw10/10#post_25307936"><img alt="View Post" class="inlineimg" src="/img/forum/go_quote.gif"></a><br><br>
I didn't want to spam with the photos, but I posted that it showed up!</div>
</div>
<br>
I want your photos in the Millennium thread the more the better, as long as sexpot bro is ok.<br><br>
I don't want to be the ONLY photo guy that contributes to that thread. <img alt="smile.gif" class="bbcode_smiley" src="http://files.overclock.net/images/smilies/smile.gif">
Discussion Starter #19
<a class="H-lightbox-open" href="http://www.overclock.net/content/type/61/id/2818374/"><img alt="" class="lightbox-enabled" data-id="2818374" data-type="61" src="http://www.overclock.net/content/type/61/id/2818374/width/350/height/700/flags/LL" style="; width: 350px; height: 197px"></a><br><a class="H-lightbox-open" href="http://www.overclock.net/content/type/61/id/2818376/"><img alt="" class="lightbox-enabled" data-id="2818376" data-type="61" src="http://www.overclock.net/content/type/61/id/2818376/width/350/height/700/flags/LL" style="; width: 350px; height: 197px"></a><br><a class="H-lightbox-open" href="http://www.overclock.net/content/type/61/id/2818377/"><img alt="" class="lightbox-enabled" data-id="2818377" data-type="61" src="http://www.overclock.net/content/type/61/id/2818377/width/350/height/700/flags/LL" style="; width: 350px; height: 197px"></a><br><a class="H-lightbox-open" href="http://www.overclock.net/content/type/61/id/2818380/"><img alt="" class="lightbox-enabled" data-id="2818380" data-type="61" src="http://www.overclock.net/content/type/61/id/2818380/width/350/height/700/flags/LL" style="; width: 350px; height: 197px"></a><br><a class="H-lightbox-open" href="http://www.overclock.net/content/type/61/id/2818381/"><img alt="" class="lightbox-enabled" data-id="2818381" data-type="61" src="http://www.overclock.net/content/type/61/id/2818381/width/350/height/700/flags/LL" style="; width: 350px; height: 197px"></a><br><a class="H-lightbox-open" href="http://www.overclock.net/content/type/61/id/2818382/"><img alt="" class="lightbox-enabled" data-id="2818382" data-type="61" src="http://www.overclock.net/content/type/61/id/2818382/width/350/height/700/flags/LL" style="; width: 350px; height: 197px"></a><br><a class="H-lightbox-open" href="http://www.overclock.net/content/type/61/id/2818383/"><img alt="" class="lightbox-enabled" data-id="2818383" data-type="61" src="http://www.overclock.net/content/type/61/id/2818383/width/350/height/700/flags/LL" style="; width: 350px; height: 197px"></a><br><a class="H-lightbox-open" href="http://www.overclock.net/content/type/61/id/2818384/"><img alt="" class="lightbox-enabled" data-id="2818384" data-type="61" src="http://www.overclock.net/content/type/61/id/2818384/width/350/height/700/flags/LL" style="; width: 350px; height: 197px"></a><br><a class="H-lightbox-open" href="http://www.overclock.net/content/type/61/id/2818385/"><img alt="" class="lightbox-enabled" data-id="2818385" data-type="61" src="http://www.overclock.net/content/type/61/id/2818385/width/350/height/700/flags/LL" style="; width: 350px; height: 197px"></a><br><a class="H-lightbox-open" href="http://www.overclock.net/content/type/61/id/2818386/"><img alt="" class="lightbox-enabled" data-id="2818386" data-type="61" src="http://www.overclock.net/content/type/61/id/2818386/width/350/height/700/flags/LL" style="; width: 350px; height: 197px"></a><br><a class="H-lightbox-open" href="http://www.overclock.net/content/type/61/id/2818387/"><img alt="" class="lightbox-enabled" data-id="2818387" data-type="61" src="http://www.overclock.net/content/type/61/id/2818387/width/350/height/700/flags/LL" style="; width: 350px; height: 197px"></a><br><a class="H-lightbox-open" href="http://www.overclock.net/content/type/61/id/2818388/"><img alt="" class="lightbox-enabled" data-id="2818388" data-type="61" src="http://www.overclock.net/content/type/61/id/2818388/width/350/height/700/flags/LL" style="; width: 350px; height: 197px"></a><br><a class="H-lightbox-open" href="http://www.overclock.net/content/type/61/id/2818389/"><img alt="" class="lightbox-enabled" data-id="2818389" data-type="61" src="http://www.overclock.net/content/type/61/id/2818389/width/350/height/700/flags/LL" style="; width: 350px; height: 197px"></a><br><a class="H-lightbox-open" href="http://www.overclock.net/content/type/61/id/2818390/"><img alt="" class="lightbox-enabled" data-id="2818390" data-type="61" src="http://www.overclock.net/content/type/61/id/2818390/width/350/height/700/flags/LL" style="; width: 350px; height: 197px"></a><br><a class="H-lightbox-open" href="http://www.overclock.net/content/type/61/id/2818391/"><img alt="" class="lightbox-enabled" data-id="2818391" data-type="61" src="http://www.overclock.net/content/type/61/id/2818391/width/350/height/700/flags/LL" style="; width: 350px; height: 197px"></a><br><a class="H-lightbox-open" href="http://www.overclock.net/content/type/61/id/2818392/"><img alt="" class="lightbox-enabled" data-id="2818392" data-type="61" src="http://www.overclock.net/content/type/61/id/2818392/width/350/height/700/flags/LL" style="; width: 350px; height: 197px"></a><br><a class="H-lightbox-open" href="http://www.overclock.net/content/type/61/id/2818393/"><img alt="" class="lightbox-enabled" data-id="2818393" data-type="61" src="http://www.overclock.net/content/type/61/id/2818393/width/350/height/700/flags/LL" style="; width: 350px; height: 197px"></a><br><a class="H-lightbox-open" href="http://www.overclock.net/content/type/61/id/2818394/"><img alt="" class="lightbox-enabled" data-id="2818394" data-type="61" src="http://www.overclock.net/content/type/61/id/2818394/width/350/height/700/flags/LL" style="; width: 350px; height: 197px"></a><br><a class="H-lightbox-open" href="http://www.overclock.net/content/type/61/id/2818395/"><img alt="" class="lightbox-enabled" data-id="2818395" data-type="61" src="http://www.overclock.net/content/type/61/id/2818395/width/350/height/700/flags/LL" style="; width: 350px; height: 197px"></a><br><a class="H-lightbox-open" href="http://www.overclock.net/content/type/61/id/2818396/"><img alt="" class="lightbox-enabled" data-id="2818396" data-type="61" src="http://www.overclock.net/content/type/61/id/2818396/width/350/height/700/flags/LL" style="; width: 350px; height: 622px"></a><br><a class="H-lightbox-open" href="http://www.overclock.net/content/type/61/id/2818397/"><img alt="" class="lightbox-enabled" data-id="2818397" data-type="61" src="http://www.overclock.net/content/type/61/id/2818397/width/350/height/700/flags/LL" style="; width: 350px; height: 622px"></a><br><a class="H-lightbox-open" href="http://www.overclock.net/content/type/61/id/2818398/"><img alt="" class="lightbox-enabled" data-id="2818398" data-type="61" src="http://www.overclock.net/content/type/61/id/2818398/width/350/height/700/flags/LL" style="; width: 350px; height: 197px"></a><br><a class="H-lightbox-open" href="http://www.overclock.net/content/type/61/id/2818399/"><img alt="" class="lightbox-enabled" data-id="2818399" data-type="61" src="http://www.overclock.net/content/type/61/id/2818399/width/350/height/700/flags/LL" style="; width: 350px; height: 197px"></a><br><a class="H-lightbox-open" href="http://www.overclock.net/content/type/61/id/2818400/"><img alt="" class="lightbox-enabled" data-id="2818400" data-type="61" src="http://www.overclock.net/content/type/61/id/2818400/width/350/height/700/flags/LL" style="; width: 350px; height: 197px"></a><br><a class="H-lightbox-open" href="http://www.overclock.net/content/type/61/id/2818401/"><img alt="" class="lightbox-enabled" data-id="2818401" data-type="61" src="http://www.overclock.net/content/type/61/id/2818401/width/350/height/700/flags/LL" style="; width: 350px; height: 197px"></a><br><a class="H-lightbox-open" href="http://www.overclock.net/content/type/61/id/2818402/"><img alt="" class="lightbox-enabled" data-id="2818402" data-type="61" src="http://www.overclock.net/content/type/61/id/2818402/width/350/height/700/flags/LL" style="; width: 350px; height: 197px"></a><br><br>
Updated the BIOS to 0801 and Windows 10 is currently installing.
Old to Overclock.net
<div class="quote-container" data-huddler-embed="/t/1603758/build-log-arcane-sanctum-magnum-thw10/10#post_25308084" data-huddler-embed-placeholder="false"><span>Quote:</span>
<div class="quote-block">Originally Posted by <strong>iBruce</strong> <a href="/t/1603758/build-log-arcane-sanctum-magnum-thw10/10#post_25308084"><img alt="View Post" class="inlineimg" src="/img/forum/go_quote.gif"></a><br><br><div class="quote-container" data-huddler-embed="/t/1603758/build-log-arcane-sanctum-magnum-thw10/10#post_25307936" data-huddler-embed-placeholder="false"><span>Quote:</span>
</div>
<br>
I don't want to be the ONLY photo guy that contributes to that thread. <img alt="smile.gif" class="bbcode_smiley" src="http://files.overclock.net/images/smilies/smile.gif"></div>
</div>
Well, you're not, you know!<img alt="tongue.gif" class="bbcode_smiley" src="http://files.overclock.net/images/smilies/tongue.gif"><br><br>
Certainly, they are some of the very best photos, but still!<img alt="biggrin.gif" class="bbcode_smiley" src="http://files.overclock.net/images/smilies/biggrin.gif"><br><br><div class="quote-container" data-huddler-embed="/t/1603758/build-log-arcane-sanctum-magnum-thw10/10#post_25308414" data-huddler-embed-placeholder="false"><span>Quote:</span>
<div class="quote-block">Originally Posted by <strong>Spirillum</strong> <a href="/t/1603758/build-log-arcane-sanctum-magnum-thw10/10#post_25308414"><img alt="View Post" class="inlineimg" src="/img/forum/go_quote.gif"></a><br><br><a class="spoiler-link H-spoiler-toggle" href="#"><strong>Warning: Spoiler!</strong> <span class="spoiler-help">(Click to show)</span></a><div class="spoiler-hidden"><a class="H-lightbox-open" href="http://www.overclock.net/content/type/61/id/2818374/"><img alt="" class="lightbox-enabled" data-id="2818374" data-type="61" src="http://www.overclock.net/content/type/61/id/2818374/width/350/height/700/flags/LL" style="; width: 350px; height: 197px"></a><br><a class="H-lightbox-open" href="http://www.overclock.net/content/type/61/id/2818376/"><img alt="" class="lightbox-enabled" data-id="2818376" data-type="61" src="http://www.overclock.net/content/type/61/id/2818376/width/350/height/700/flags/LL" style="; width: 350px; height: 197px"></a><br><a class="H-lightbox-open" href="http://www.overclock.net/content/type/61/id/2818377/"><img alt="" class="lightbox-enabled" data-id="2818377" data-type="61" src="http://www.overclock.net/content/type/61/id/2818377/width/350/height/700/flags/LL" style="; width: 350px; height: 197px"></a><br><a class="H-lightbox-open" href="http://www.overclock.net/content/type/61/id/2818380/"><img alt="" class="lightbox-enabled" data-id="2818380" data-type="61" src="http://www.overclock.net/content/type/61/id/2818380/width/350/height/700/flags/LL" style="; width: 350px; height: 197px"></a><br><a class="H-lightbox-open" href="http://www.overclock.net/content/type/61/id/2818381/"><img alt="" class="lightbox-enabled" data-id="2818381" data-type="61" src="http://www.overclock.net/content/type/61/id/2818381/width/350/height/700/flags/LL" style="; width: 350px; height: 197px"></a><br><a class="H-lightbox-open" href="http://www.overclock.net/content/type/61/id/2818382/"><img alt="" class="lightbox-enabled" data-id="2818382" data-type="61" src="http://www.overclock.net/content/type/61/id/2818382/width/350/height/700/flags/LL" style="; width: 350px; height: 197px"></a><br><a class="H-lightbox-open" href="http://www.overclock.net/content/type/61/id/2818383/"><img alt="" class="lightbox-enabled" data-id="2818383" data-type="61" src="http://www.overclock.net/content/type/61/id/2818383/width/350/height/700/flags/LL" style="; width: 350px; height: 197px"></a><br><a class="H-lightbox-open" href="http://www.overclock.net/content/type/61/id/2818384/"><img alt="" class="lightbox-enabled" data-id="2818384" data-type="61" src="http://www.overclock.net/content/type/61/id/2818384/width/350/height/700/flags/LL" style="; width: 350px; height: 197px"></a><br><a class="H-lightbox-open" href="http://www.overclock.net/content/type/61/id/2818385/"><img alt="" class="lightbox-enabled" data-id="2818385" data-type="61" src="http://www.overclock.net/content/type/61/id/2818385/width/350/height/700/flags/LL" style="; width: 350px; height: 197px"></a><br><a class="H-lightbox-open" href="http://www.overclock.net/content/type/61/id/2818386/"><img alt="" class="lightbox-enabled" data-id="2818386" data-type="61" src="http://www.overclock.net/content/type/61/id/2818386/width/350/height/700/flags/LL" style="; width: 350px; height: 197px"></a><br><a class="H-lightbox-open" href="http://www.overclock.net/content/type/61/id/2818387/"><img alt="" class="lightbox-enabled" data-id="2818387" data-type="61" src="http://www.overclock.net/content/type/61/id/2818387/width/350/height/700/flags/LL" style="; width: 350px; height: 197px"></a><br><a class="H-lightbox-open" href="http://www.overclock.net/content/type/61/id/2818388/"><img alt="" class="lightbox-enabled" data-id="2818388" data-type="61" src="http://www.overclock.net/content/type/61/id/2818388/width/350/height/700/flags/LL" style="; width: 350px; height: 197px"></a><br><a class="H-lightbox-open" href="http://www.overclock.net/content/type/61/id/2818389/"><img alt="" class="lightbox-enabled" data-id="2818389" data-type="61" src="http://www.overclock.net/content/type/61/id/2818389/width/350/height/700/flags/LL" style="; width: 350px; height: 197px"></a><br><a class="H-lightbox-open" href="http://www.overclock.net/content/type/61/id/2818390/"><img alt="" class="lightbox-enabled" data-id="2818390" data-type="61" src="http://www.overclock.net/content/type/61/id/2818390/width/350/height/700/flags/LL" style="; width: 350px; height: 197px"></a><br><a class="H-lightbox-open" href="http://www.overclock.net/content/type/61/id/2818391/"><img alt="" class="lightbox-enabled" data-id="2818391" data-type="61" src="http://www.overclock.net/content/type/61/id/2818391/width/350/height/700/flags/LL" style="; width: 350px; height: 197px"></a><br><a class="H-lightbox-open" href="http://www.overclock.net/content/type/61/id/2818392/"><img alt="" class="lightbox-enabled" data-id="2818392" data-type="61" src="http://www.overclock.net/content/type/61/id/2818392/width/350/height/700/flags/LL" style="; width: 350px; height: 197px"></a><br><a class="H-lightbox-open" href="http://www.overclock.net/content/type/61/id/2818393/"><img alt="" class="lightbox-enabled" data-id="2818393" data-type="61" src="http://www.overclock.net/content/type/61/id/2818393/width/350/height/700/flags/LL" style="; width: 350px; height: 197px"></a><br><a class="H-lightbox-open" href="http://www.overclock.net/content/type/61/id/2818394/"><img alt="" class="lightbox-enabled" data-id="2818394" data-type="61" src="http://www.overclock.net/content/type/61/id/2818394/width/350/height/700/flags/LL" style="; width: 350px; height: 197px"></a><br><a class="H-lightbox-open" href="http://www.overclock.net/content/type/61/id/2818395/"><img alt="" class="lightbox-enabled" data-id="2818395" data-type="61" src="http://www.overclock.net/content/type/61/id/2818395/width/350/height/700/flags/LL" style="; width: 350px; height: 197px"></a><br><a class="H-lightbox-open" href="http://www.overclock.net/content/type/61/id/2818396/"><img alt="" class="lightbox-enabled" data-id="2818396" data-type="61" src="http://www.overclock.net/content/type/61/id/2818396/width/350/height/700/flags/LL" style="; width: 350px; height: 622px"></a><br><a class="H-lightbox-open" href="http://www.overclock.net/content/type/61/id/2818397/"><img alt="" class="lightbox-enabled" data-id="2818397" data-type="61" src="http://www.overclock.net/content/type/61/id/2818397/width/350/height/700/flags/LL" style="; width: 350px; height: 622px"></a><br><a class="H-lightbox-open" href="http://www.overclock.net/content/type/61/id/2818398/"><img alt="" class="lightbox-enabled" data-id="2818398" data-type="61" src="http://www.overclock.net/content/type/61/id/2818398/width/350/height/700/flags/LL" style="; width: 350px; height: 197px"></a><br><a class="H-lightbox-open" href="http://www.overclock.net/content/type/61/id/2818399/"><img alt="" class="lightbox-enabled" data-id="2818399" data-type="61" src="http://www.overclock.net/content/type/61/id/2818399/width/350/height/700/flags/LL" style="; width: 350px; height: 197px"></a><br><a class="H-lightbox-open" href="http://www.overclock.net/content/type/61/id/2818400/"><img alt="" class="lightbox-enabled" data-id="2818400" data-type="61" src="http://www.overclock.net/content/type/61/id/2818400/width/350/height/700/flags/LL" style="; width: 350px; height: 197px"></a><br><a class="H-lightbox-open" href="http://www.overclock.net/content/type/61/id/2818401/"><img alt="" class="lightbox-enabled" data-id="2818401" data-type="61" src="http://www.overclock.net/content/type/61/id/2818401/width/350/height/700/flags/LL" style="; width: 350px; height: 197px"></a><br><a class="H-lightbox-open" href="http://www.overclock.net/content/type/61/id/2818402/"><img alt="" class="lightbox-enabled" data-id="2818402" data-type="61" src="http://www.overclock.net/content/type/61/id/2818402/width/350/height/700/flags/LL" style="; width: 350px; height: 197px"></a></div>
<br>
Updated the BIOS to 0801 and Windows 10 is currently installing.</div>
</div>
Whoa!<br><img alt="drool.gif" class="bbcode_smiley" src="http://files.overclock.net/images/smilies/drool.gif"><br><br>
Suberoni!<br><br>
Beautiful hardware, and photos, I hate to have to spoiler tag 'em!<br><br>
Rep+<img alt="thumb.gif" class="bbcode_smiley" src="http://files.overclock.net/images/smilies/thumb.gif">
1 - 20 of 164 Posts
