1 - 4 of 4 Posts
___________
Album
I decided to build the hardware from my last personal build into a new case/loop.
Mods:
  • I really like the symmetry and "full" look that comes with a 560 in the top panel but I'm not a huge fan of the extended top options for this case. So I picked up an extra 560 drop in and cut/drilled the top panel to fit the whole assembly.
  • I cut pass-through holes in the divider panel to support two "hanging" reservoirs, the radiator outlet, and the monoblock pipes. I had to trim the middle support tab off of the top motherboard rail but it's still held in place using the other two. The only thing word of caution I'll give here is to put the reservoir outlet somewhere else if you plan on using the front fan rack. With the 560 in place, the outlet pass-through and 90° fitting are too close to the edge of the case to fit the rack back in.
  • I drilled out the basement floor to mount both pumps, the Aquaero 6 LT, and a stock hard drive cage. If I ever upgrade the power supply to something longer, the drive cage will need to be moved.
  • There's pass-throughs on the motherboard tray that don't interfere with any stand-off holes in case I want to convert to full ATX/EATX in the future. I also killed all the RGB in the main chamber because RGB is for quitters.
CPU: Intel - Core i7-6700K 4GHz Quad-Core Processor ($358.89 @ B&H)
Motherboard: Asus - MAXIMUS VIII GENE Micro ATX LGA1151 Motherboard ($139.91 @ Amazon)
Memory: Corsair - Dominator Platinum 16GB (2 x 8GB) DDR4-3200 Memory ($219.99 @ Amazon)
Storage: Samsung - 860 Evo 500GB 2.5" Solid State Drive ($126.94 @ Amazon)
Storage: Samsung - 840 Pro Series 512GB 2.5" Solid State Drive ($305.00)
Storage: Samsung - 960 PRO 512GB M.2-2280 Solid State Drive ($290.00 @ Amazon)
Storage: Seagate - Barracuda 3TB 3.5" 7200RPM Internal Hard Drive ($81.00 @ Amazon)
Video Card: EVGA - GeForce GTX 1080 8GB FTW Gaming ACX 3.0 Video Card (2-Way SLI) ($579.99)
Power Supply: Cooler Master - V1000 1000W 80+ Gold Certified Fully-Modular ATX Power Supply ($194.99 @ Walmart)
Operating System: Microsoft - Windows 7 Home Premium SP1 OEM 64-bit ($119.89 @ OutletPC)
Case Fan: Corsair - Air Series AF120 Quiet Edition 39.9 CFM 120mm Fan ($12.11 @ OutletPC)
Case Fan: Corsair - ML140 Pro 97.0 CFM 140mm Fan ($26.47)
Other: Black Ice Nemesis 560GTX ($168.95)
Other: EK-FC1080 GTX FTW Nickel Block + Backplate ($135.00)
Other: EK-XTOP Revo D5 PWM Plexi ($119.00)
Other: CaseLabs Magnum SMA8-A ($713.90)
Other: Black Ice Nemesis 560GTS ($107.95)
Other: Monsoon MMRS Reservoirs x2 ($208.00)
Other: Mayhems Pastel Blue ($53.85)
Other: Bitspower/Barrow Fittings ($200.00)
Other: Aquaero 6 LT + Heatsink ($120.00)
Other: EK-XTOP Revo D5 PWM Plexi ($125.00)
Other: EK-FC1080 GTX FTW - Nickel ($140.00)
Other: EK-FC1080 GTX FTW Backplate - Black ($40.00)
Other: EK-FB Asus M8G Monoblock ($137.00)
Other: CableMod Cables ($297.00)
Total: $5786.11
Generated by PCPartPicker 2018-06-12 18:35 EDT-0400
1 - 4 of 4 Posts
