1 - 3 of 3 Posts
1/2" Tubing does not fit 12mm fittings, at all. I was't patient enough so sand it down smoothly and by hand, so I did it all with a table sander. Everything sealed up nicely, so for now that's it for her.
Leak testes for 24 hours and no leaks at all.
Other than replacing the tubing with proper tubing, any other suggestions?
Maybe paint the "top covers" of the ram-blocks white and try to see how it would look if you change 1 or 2 of the white rings on the fans to the red ones...
otherwise a very nice build sir
Nice job! The only thing that stands out to me, and it might just be the camera angle. The tubing runs looks a little wonky to me. Maybe some of the tubing runs are just a little to long or a little to short. Try and make them all run perfectly parallel and/or perpendicular to each other. This looks like its going to be a show piece. Don't get me wrong you've done a very nice job here.
1 - 3 of 3 Posts
