An updated list is located in Post #11.
I am currently assisting an online friend with, what I consider to be, an enormous waste of money.
With that said, the person is completely comfortable (beyond financially stable) with the price range and everything I've done to cut down has been met with resistance. I say all this to avoid the obvious instructions to taper down this build. It's not happening. (Not being rude in the slightest, just wanted to get that out there.)
The person does a lot of heavy calculations for his work and while this is a gaming computer, it also a work computer. Large scale modeling, macro-economic calculations, CAD, etc.
This is my initial build while just talking to him. It's not final in the least but I did want to get the review of others.
My current uncertainties lie in the cooling selection against upgrading to the far more expensive 3960k or 3970k. Whether the motherboard is the best possible selection. If the GeForce Titan would be more appropriate for modeling against the 690 (my knowledge of the Titan is beyond limited at the moment). Or if two 680s, three 680s, or three 670s would be the better route. Everything else I feel relatively comfortable with.
I have came to these forums before and received some excellent criticisms in builds that I found invaluable. I am hoping lightning can strike again here with this build. I thank anyone in advance for their criticisms and recommendations.
PCPartPicker part list / Price breakdown by merchant / Benchmarks
CPU: Intel Core i7-3930K 3.2GHz 6-Core Processor ($499.99 @ Microcenter)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($32.98 @ Amazon)
Thermal Compound: Prolimatech PK-3 Nano Aluminum High-Grade 1.5g Thermal Paste
Motherboard: Asus Sabertooth X79 ATX LGA2011 Motherboard ($325.99 @ SuperBiiz)
Memory: Mushkin Redline 16GB (2 x 8GB) DDR3-1866 Memory ($132.99 @ Newegg)
Storage: Western Digital Caviar Black 2TB 3.5" 7200RPM Internal Hard Drive ($157.99 @ Adorama)
Storage: Samsung 840 Pro Series 512GB 2.5" Solid State Disk ($449.99 @ Adorama)
Video Card: EVGA GeForce GTX 690 4GB Video Card ($984.99 @ SuperBiiz)
Case: Cooler Master HAF 932 Advanced ATX Full Tower Case ($171.10 @ TigerDirect)
Power Supply: SeaSonic 760W 80 PLUS Platinum Certified ATX12V / EPS12V Power Supply ($168.98 @ SuperBiiz)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer ($19.98 @ Outlet PC)
Operating System: Microsoft Windows 7 Ultimate SP1 (OEM) (64-bit) ($179.98 @ Outlet PC)
Monitor: Asus VN247H-P 23.6" Monitor ($177.99 @ Amazon)
Monitor: Asus VG248QE 144Hz 24.0" Monitor ($279.00 @ Amazon)
Keyboard: Das Keyboard Model S Ultimate Silent Wired Standard Keyboard ($127.94 @ Adorama)
Total: $4020.87
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2013-02-27 03:43 EST-0500)
Total: $4020.87
