1 - 3 of 3 Posts
Hi,
My first time water cooling but I am not sure which pump to install for my build.
I currently have a 750D corsair case and planning to water cool cpu, gpu, and motherboard blocks with a single 360 rad. Planning to use petg tubing and probably seven 90 degree bends.
Will a D5 be enough? or a DDC?
Thanks,
-keep 90 degrees to a minimum
-MB blocks other then a full cover or CPU only are a waste of money and just add restrictions
-CPU + GPU on ONE 360 if you're not planning (insane) OC and dont have a problem with *some* noise
-always buy more fittings as you think you'll need
Any D5 or DDC will do.
Note: new to wc and jumping straight into hardline..... make sure you don underestimate this... buy several feet extra of hardline to practice with; with hardline you cant just "wing it" or "that'll be close enough". Close only counts in horseshoes and hand grenades. Cutting 2mm too short or not straight will cause problems/leaks.
Thanks, very informative.
I am planning to OC the cpu to 4GHz to possibly 4.2 - 4.5. I doubt I will touch the gpu settings.
1 - 3 of 3 Posts
