1 - 19 of 19 Posts
I'll be recycling few parts from my old rig before making a move to 6 core which will take me sometime to build so I'm building lean mean-back up until I get there
This is my first "Build Log" but it's not my first build
Here is what I'm trying to accomplish;
BUDGET
SILENT
LEAN-SINGLE GPU SOLUTION
Name -El Impacto-Haze
. : Hardware Spec : .
Case: Fractal Design Arc Midi R2 FD-CA-ARC-R2-BL-W Black Steel ATX Mid Tower Computer Case [$60 from Egg]
CPU: Intel i7 4770k
GPU: 1x EVGA GTX 780 Classy (I could end up with 780TI or Titan )
MB: Asus M6 Impact ( sick board ) tested and approved
Ram:Trident X 2600c10
PSU: CM -V1000
. : Watercooling Spec : .
Pump: Koolance 400
Pump Cov: Aquacomputer aquacover DDC
CPU Block: Koolance 380
GPU Block: EK or Aquacomputer
Rad 1: XSPC RX 240
Rad 2: Alphacool NexXxoS ST30 Full Copper 240mm
Rad 3:Hardware Labs Black ICE Radiator SR1 140
Resevoir: Bitspower Water Tank Z-Multi 150
Fittings: Bitspower
Tubing: Tygon A-60-G Norprene 19/13mm (1/2ID)
Fans: Some that came with the case and some GT's
Stay tune
IMG_0039_zps9825eb7d.jpg~original
back at it
subbed :O
did you put snow on your motherboard or was it someone else?
and why a MITX board in a full ATX case? it would look so unproportional...
Originally Posted by barkinos98 View Post
subbed :O
why not
-budget + working with what I got (will make it proportional )
Fluffy Fennec Foxes!
Subbed because this looks like it'll be a fun one!
I'm not sure if I should make the 140MM+bottom fan sucking fresh air or blowing it out
Very interesting, curious to see what youll do with the bottom 120mm rad!
some new parts arrived today,hopefully will get another delivery by Friday so I can get going
this is my third CPU-3xx from Koolance ,great "manifold"
here is another option (will probably delay the build since this was just posted "available soon " )
P.S. I have to work on my picture taking technique ,sorry for the first few ,it should get better down the road (Exilim EX-Z90
Discussion Starter · #8 ·
Discussion Starter · #9 ·
Discussion Starter · #15 ·
Originally Posted by coolhandluke41 View Post
I'm going nuts here .For the life of me, I can't figure out what I did with this two plastic covers ,anyone knows where I can get the replacements ??
http://s774.photobucket.com/user/coolhand_SS/media/rem_zps4869eefe.jpg.html
Check on ebay Luke? Seems to be quite a few on there and they will all be the same size I assume since the drives used in their place will be the same size?
Guess it'd be a matter of matching colour/finish.
http://www.ebay.com/bhp/drive-bay-cover
Discussion Starter · #17 ·
I'm going to contact Fractal and get the original (I have some other covers from previous builds but the mounting mechanism is different -don't want to disassemble the front just for the covers )
Thank you
Discussion Starter · #19 ·
1 - 19 of 19 Posts
