This will be my 24/7 rig ,I was going to build around SilverStone Temjin SST-TJ07BW but changed my mind when I noticed the capability of 750D
Name -White Widow
. : Hardware Spec : .
Case:Corsair Obsidian 750D Black ATX Full Tower
CPU: Intel i7 4930K
GPU: 2x EVGA GTX 780 Classy
MB: Maximus Rampage IV Gene
Ram:Trident X 2600c10 or Team Xtreme 2400 c9 (16gb)
PSU: SuperNOVA 1300 G2
SSD-Samsung 840 128gb and Adata SP900 128gb
HDD-WD 1Tb Blue
. : Watercooling Spec : .
1x Koolance 380i
2x Swiftech GTX 780 Hydro Copper Classified+ Back-plates+EVGA Pro SLI Bridge
1x Alphacool NexXxoS XT45 Full Copper Triple 140mm
1x Alphacool NexXxoS UT60 Full Copper Dual 140mm
2 x Swiftech G¼ Male-Male Lok-Seal™ Short Extension Fitting (11-18mm Range) - Black
7 x Yate Loon 140mm Medium Speed Silent Case Fan - D14SM-12 - Sleeved
- Cable: Convert to 3-Pin only (Cut off extra connectors) - Sleeved
- Sleeve Color: Black
- Heatshrink Color: Black
1 x Bitspower Water Tank Z-Multi 150 - Limited White POM Edition
- Nozzles: No Nozzles
1 x Swiftech MCP35X-WT™ 12 VDC Pump
- Fitting Size: No Fittings
1 x EK-DDC Heatsink Housing - Nickel
1 x SATA 3.0 (6Gbit/s) Round Cable Straight to Straight - 24" - Black
2 x PrimoChilll 1/2" OD Rigid Acrylic Tube - 4x 24" + Black and Chrome PrimoChilll fittings
1 x Bitspower X-Station Power Extension I - Red LED (BP-XSP1M-RD)
2 x ACRYLITE ACRYLIC PLEXIGLASS WHITE TRANSLUCENT
1 x Bitfenix Alchemy Multisleeve 24-Pin ATX Extension Cable
4 x Bitfenix Alchemy Multisleeve 8-Pin PCI-E Extension Cable
to be continued..
thanks to JackNaylorPE for making this spreadsheet based on Matins data ,here you can see the difference when it comes to slow-medium fans on 120mm vs 140mm RAD
choice of fans was pretty easy since this were around for sometime
here is comparison (140mm ) D14SM-12 vs. (120mm) GT AP15+ adapter
Semi-Finish
http://www.overclock.net/t/1455785/build-log-4930k-rampage-iv-gene-corsair-750d-nexxxos-280-420/20#post_21615807
Name -White Widow
CPU: Intel i7 4930K
HDD-WD 1Tb Blue
1x Koolance 380i
to be continued..
Semi-Finish
