Old build link : http://www.overclock.net/forums/threads/add/forumId/61
Key:
New parts:
900D case - Got this thing at 8:30am today.
http://imgur.com/a/pS77X
Key:
- Already owned parts
- Ordered parts
- New parts
- Planning to buy soon
- Corsair 900D case
- 1 Intel Core i5 2500K Cpu
- 1 Nvidia Gforce GTX 590
- 1 GELID PWM Y-Cable
- 6 Koolance Hose Clamp for OD 19mm (3/4in)
- 1 Black Ice GT Xtreme 240 Radiator
- 2 Bitspower G1/4 Matte Black Dual Rotary Angle Comp. Fitting
- 2 XSPC High Flex Hose, 1/2, Clear/UV Blue
- 3 Bitspower UV Reactive Cable Sleeve Kit Blue
- 2 GELID Wing 12 120mm UV Blue Fan
- 1 Swiftech MCRES Micro Rev2 Reservoir
- 1 Koolance PMP-450 12V Variable Speed Pump
- 1 Koolance VID-NX590 Reference GTX 590 VGA Cooler
- 4 Bitspower G1/4 Matte Black 1/2 Fitting
- 1 Bitspower Dual 30cm Cold Cathode Kit UV
- 2 Chrome Fan Grill 120mm
- 1 G.Skill Ripjaws F3-12800CL9D-8GBRL 8GB (2x4GB) DDR3
- 3 XSPC High Flex Hose, 1/2, Clear/UV Blue
- 7 Koolance Hose Clamp for OD 19mm (3/4in)
- 7 Bitspower G1/4 Matte Black 1/2 Fitting
- 1 XSPC EX120 Radiator
- 1 XSPC RayStorm CPU Waterblock for Intel
- 1 XSPC EX240 Radiator
- 1 GELID Wing 12 120mm Blue Multipack
New parts:
- 1 Aplhacool nexXxos UT60 full copper 480mm or phobya G-changer 480 v2 full copper
- 1 AMD R9 290X or GTX 780
- GPU water block
- Ek supremacy Naked Ivy mount
- i5 3570K (Planning on delidding)
- 1 Seasonic 1000W XT platinum power supply
- 4 Corsair Sp quiet edition fans
- MDPC-X cable sleeving - Red and Black
- Black Primochill rigid tubing
Red Primochill rigid tubign
4 Bitspower G1/4 Deep blood red rotary 90 Degree IG 1/4 Extenders
- 4 Anodized silver Primochill Rigid Fittings 4 pack
- White colour cold cathode (Spectral white bar)
- Primochill silicone bending tube
34 Modsmart 4 cable Bundlers
- 600mm x 600mm ; 3mm thick Acrylic panel for midplate
- Ek Mobo waterblock for maximus V Formula
- Ek supremacy Waterblock for CPU
- RBG led strips (ordered from e bay)
- 3M Di-noc
- Stickers: Asus ROG and Nividia
- 1 Asus Maximus V formula with AC 3 game Mobo
- 1 BitFenix Sleeved 8pin EPS 12V Extension 45cm Red/Black
- 3 BitFenix Sleeved 4-Pin Molex Power Splitter Red/Black
- 1 XSPC FLX Tubing Red UV 1/2ID 3/4OD 2m
- 1 BitFenix Sleeved 24pin ATX Extension Cable 30cm Red/Black
- 2 BitFenix Sleeved 8-Pin VGA Power Cable 45cm Red/Black
- 1 XSPC Twin 3mm LED Kit Red
- 1 XSPC Twin 3mm LED Kit UV
- 2 Bitspower G1/4 Deep Blood Red Rotary Angle 1/2 Fitting
- 4 Bitspower Matte Black Rotary 45 Degree 1/2 Fitting
- 1 Bitspower D5 Mod Top V2 Acrylic
- 1 Bitspower D5/MCP655 Pump Mod Kit Red
- 1 Bitspower Dual/Single D5 Top Upgrade Kit 150
