Hello everyone!
I think this was long overdue, but here goes nothing
. I've always wanted to make a build log, but a little hesitant, why? I honestly don't know. I settled on 911 as my rig's name a while ago; inspired by Need For Speed Most Wanted (I just like playing as a cop)
. I've gone a little far already, but i still have a lot to do, so stay tuned!
RIG SPECS:
CPU: Intel Core i7 5930k
Mobo: MSI X99S SLI Krait Edition
RAM: DDR4 Kingston Hyper X 3000Mhz CL15 16gb (x4 4GB)
GPU: Gigabyte G1 Gaming GTX 970 (x2)
PSU: Corsair HX 1050w
SSD: 256gb Crucial m4
HDD: 500Gb Seagate 7200RPM (x2)
OS: Win 8.1 Pro
Case: 600t
COOLING PARTS:
CPU: XSPC RayStorm High Performance Acetal waterblock
GPU: EK-FC970 GTX WF3 - Nickel (x2)
GPU: EK-FC Terminal DUAL Parallel - Plexi
GPU: EK-FC970 GTX WF3 Backplate - Black (x2)
RES: XSPC Photon 270 Tube Reservoir Reservoir
RES: Monsoon Series Two Premium Bay Reservior
PUMP: MCP655 PWM
PUMP: Alphacool DC-LT 2400
RAD: XSPC EX360 Crossflow Triple 360mm
RAD: Alphacool NexXxoS Monsta 240mm
RAD: Phobya G-Changer 120mm Ver. 1.2
Fans: Corsair SP 120mm Fans
Tube: PrimoChill 3/8" x 1/2" Rigid PETG Tubing
Fitting: Rigid Revolver Compression Fitting 3/8" x 1/2" Diamond Knurled - Anodized White
FC: Scythe Kaze Master Pro Fan Controller
ACCESSORIES:
KB: Corsair k70 RGB
Mice: Cyborg RAT 5
Mice: Razer Naga MMO
WC: Logitech c920 1080p Webcam
HP: Logitech G35
Audio: Logitech z623 200w Sub Woofer
WORK BEGINS:
UPDATE 1: Cutting The 600T
UPDATE 2: PSU Fan Change
UPDATE 3: Painting The Case, Backplate, Fans, e.t.c.
UPDATE 4: Mini Photoshoot featuring Mobo, and GPU + EK waterblock
UPDATE 5: Installation of Core Components
UPDATE 6: Leak Testing!
UPDATE 7: Cable Management
UPDATE 8: Cooling Performance and Overclocking
RIG SPECS:
OS: Win 8.1 Pro
Case: 600t
COOLING PARTS:
PUMP: MCP655 PWM
ACCESSORIES:
KB: Corsair k70 RGB
Mice: Cyborg RAT 5
HP: Logitech G35
WORK BEGINS:
