Hi all. Once again I'm posting from my phone so please forgive any funkiness.
I'm in the process of installing the loop into my rig thus the phone posting. What I have for you all today are results from a flow test I did between using one pump and two pumps.
For the setup I used a simple method of timing how fast it takes to empty an amount of water into a measuring cup. The other good thing about this test is that I can flush the loop with some distilled water.
Setup took a bit of time. I had some trouble getting all the air out but after performing the traditional radiator dance of our peoples I was ready to go.
After doing 4 runs I consistently measured a little less than 100ml of water. I was going to do some better testing than a simple time test but my reservoir is very small, so I only had a tiny amount of water to measure before the pumps would start pulling air from the reservoir. I did attempt to extend my loop into a larger container from the reservoir but it didn't work and I just made a large mess.
So let's get scientific!
What we need first is a control. That would be the same test done but with only a single pump and radiator. This will give us the flow of the AIO is it was originally intended.
We have the single loop setup all ready to go. The amount of water in the reservoir is the amount I will use through out the testing. To try too keep it consistent I just put the water collected in the measuring cup back into the reservoir.
The other factor is where the water holds in the drain side of the loop, going into the measuring cup. The natural pressure of the loop with the tube sitting in the cup about the same place every time left about 6 inches of water consistently, so that will just have to do.
For the control I ran 3 tests which came out at an average of 6.8 seconds. Just shy of 7 seconds.
Ok! Onto the main event!
Here is the level I stopped timing at. Just as the water level hit the top of the barb fitting. If I let it go past that the pump would pull air into the radiator.
In the test I will measure the flow of 1 pump and then 2 pumps in the completed loop.
The results!
Control: 6.8 seconds.
1 pump: 11.3 seconds
2 pumps: 7.2 seconds
Ain't that interesting! We all know these pumps are small and low flow designed. From a visual test to see how well a single pump did versus 2 pumps didn't give me any indication of a difference in flow rate. Clearly there is a noticeable difference. While the impact in temperature is still to be determined we can conclude that the larger the loop the less flow a single pump will have.
With the single pump test I didn't have any trouble sucking air into the radiators when I let the reservoir empty to much so a single pump will still work.
Next up will be the temperature comparison!
The results!
