Hello everyone, I'm very excited with this build over summer. Been lurking and looking on the forum for a while but recently have been really starting to enjoy is and posting much more. This is not my first ever build however my first build log on OCN. Some new parts being used and some from the previous build. This time however I'm going to slightly mod the SM8 I have. I'll be adding in a basement/mid plate to give that cleaner look and hide the psu and pump. Main theme is going to be Black and Orange (trying to get away from the Red and Black ROG theme). Hopefully I'll try and get this build done by the end of the month. Hope you all enjoy the log (I'm not very good at taking good photo's) and hopefully this is worthy of a sub from some of you
Main Hardware
• CPU: Intel Core i7 5820K Haswell-E 3.3GHz LGA 2011-v3 [✔]
• Motherboard: Asus X99 Deluxe ATX LGA 2011-v3 [✔]
• RAM: Corsair Dominator Platinum 16GB (4 x 4GB) DDR4 2666 MHz [✔]
• GPU: EVGA GeForce GTX 980 Classified ACX 2.0 [✔]
• PSU: Corsair AX860 ATX 860 Watt 80+ Platinum [✔]
• SSD: Samsung 840 EVO 250GB 2.5" Solid State Drive [✔]
• SSD: Samsung 840 EVO 1TB 2.5" Solid State Drive [✔]
• HDD: Western Digital Black 4TB 3.5" 7200RPM Hard Drive [✔]
• Case: Caselabs Merlin SM8 [✔]
Watercooling
• EK Supremacy (Clean CSQ) w/ EVO Plexi Upgrade Kit [✔]
• EK FC 980 Classy Block [ ] ← When released in January February
• EK-Mosfet Asus X99 - Nickel [✔]
• EK-CoolStream XTX (480) [✔]
• EK-CoolStream XTX (240) [✔]
• EK-Res X3 250 w/ MultiportTop [✔]
• EK D5 Vario w/ Bitspower v2 Top [✔]
• Mayhems 15 ml Orange Dye [✔]
• E22 12/10 mm Tubing [✔]
• Cougar CF-V12HP Vortex PWM (x6) [✔]
• Noiseblocker NB-Multifram M12-P (x6) [✔]
• Noiseblocker NB-Blacksilent Pro PLPS (x7) [✔]
• Many Bitspower Black Sparkle Fittings [✔]
Other Stuff
• DarkSide CONNECT Dimmable 5.5" Modular LED Strip (White) [✔]
• DarkSide CONNECT Dimmable 7.5" Modular LED Strip (White) [✔]
• Caselabs Accessory Plate (x2) [✔]
• Caselabs Horizontal Accessory Mount [✔]
• Ensourced Custom Sleeved Cables [✔]
• Lamptron FC Touch Fan Controller [✔]
Sleeving
• 24 Pin Motherboard Cable [✔] | • 8 Pin PCI-E Cables (x2) [✔] | • 4+4 Pin CPU|EPS Cable [✔]
