how in the hell did you convince corsair to send you there grommets!?Originally Posted by Soul.;14215350
Update!
I actually did this a couple of days ago, but here it is. I got all of the holes in my case cut out to accept some corsair grommets (like in the 800D).
I used a angle grinder to widen the holes, then finished them with a dremel. The grommets kind of 'snap' into the holes, but I also stuck them in place with some hot glue to make sure they don't move.
Corsiar was kind enough to send me some grommets from the 800D:
These are all holes I had cut previously, but they could look better!
Got the first one to fit.
Finished some more, just 3 more to go.
Finished! I didn't put a grommet in that bottom hole though, it was already cut out and too large to accept one.
I'm pretty happy with how they turned out, makes the case look alot neater. Plus the grommets were free =D
More Progress on the radiator housing too! Like I said, I was building a custom radiator housing to hold the RX360. I made it out of some sheet Aluminium, here are some pics of the build!
Here's the top panel for the mount (even though I already posted it)
And I unfortunately don't have any pictures of me making the housing, my phone was dead when I was fabricating it. Made the 4 sides of the housing with shear and bent them into the right shape with a brake.
This is it taped together as a mock, ready to be welded:
All welded!
Now I need to cut out a hole in the top of the case so I can fit the rad in.
I also marked out the hole pattern I have on the bottom of the radiator housing to mount it to the case - I'm mounting it with some 4-40 screws.
And here's the housing on top of the case, just checking fit
It fit pretty good, being careful with measuring when I was fab'ing the panels made for a good fit. I ended up cleaning up the sides and filling in some gaps with body filler to get it all nice and smooth.
Painting it flat black:
Added a coat of instant clear coat, made it match my case much better, you can see the cutout of the side panel in the background
Anyways, that's all I have for now. Time to start assembling my stuff back together and mock up the loop. I'll have some more pictures of stuff going together later on! And let me know what you think so far! I could always use some feedback![]()
