Plan
So I finally get to go through with a build for my self! This build will primarily be used for work, but i do love a good game
First, is to get all the main components set up.
Second, is to get a case and get it all water cooled.
Lastly, is to go fully tubeless!
Status
I should get the first update out over Winter break (week after next). You will have to excuse my terrible photography skills for now as i am new, and only have a point n shoot Ultrasonic
Current Pictures
Parts List
Main Components
Posible Other Componants
- [Have] 3930k
- [Have] MSI XPower II
- [Have] G.Skill Ripjaw Z 64GB 2400 MHz
- [Have] (2x) 512GB Vertex 4
- [Have] (2x) HIS IceQ X2 7970
- [Need] Lepa G 1600
- [Have] XSPC Raystorm
- [Have] XSPC XPower II block
- [Have] (2x) XSPC RAM
- [Need] (2x) XSPC 7970
- [Have] (2x) MCP35X
- [Have] (2x) EK 150 Multi Res
- [Need] (2x) NexXxoS Monsta 480
- [Have] (20x) Cougar 120mm PWM
- [Need] CL MH10
- [Need] PSU support (MAC-123)
- [Need] Flex-Bay HDD cage (MAC-102)
- [Need] (2x) SSD mount (MAC-124)
- [Need] Flex-Bay 5.25 HD (MAC-127)
- [Need] Flex-bay 120mm fan (MAC-113)
- [Need] Casters HD (MAC-185)
- [Need] Moonstone 3/8 x 1/2 Compression
other then that i have no idea at the moment, but I'll look into it more when the time comes
- [Need] New Headphones
- [Have] Corsair M90
- External DAC
- Mech Keyboard
- GPU back plates from DWood
Color Scheme
Updates
