221 - 238 of 238 Posts
· BSME
whats stopping you from designing your own?
I never got around to showing off the finished product of the build i did forever ago. All it needs is the front brim to be painted red (the plastic piece with the rubber feet lining the front panel). Hope you enjoy!
Specs:
AMD A10 6800K (4.6GHz Quad)
GTX 770 MSI OC
2400MHZ 16GB Corsair RAM
240GB SSD Mushkin Chronos 550MB R/W Speed (OS/APPS)
MSI A88XI AC Motherboard
Corsair Air Series Fans x2 120mm x1 140mm
Corsair 650W HX Series PSU
3TB 7200rpm
Corsair H100i Liquid Cooler
Features:
Red SATA Cables x4 6GB/S
Red Braided Power Cables
AC WIFI
Bluetooth 4.0
Fast Boot
4 Total USB 3.0
Gear:
Razer Naga Molten
Steel Series Merc Stealth
Tritton 720 (Xbox/Playstation Version will work if you have and optical port)
27in 1920x1200 Monitor
Hi all,
So yes, I do apologize on behalf of both of us for how slow this build is going. Ninja and I both have just entered our senior year of highschool, and between musical, academic, and athletic commitments, the build has made virtually no progress. We are both anticipating and hoping that after our schedules get into a good routine, things should settle down, and we should be able to get some work done on this! WORST case, after we're accepted to college, 2nd semester will be a breeze, and we will finally start than. Wish us luck at our ocean of AP's this year, and making it into some nice colleges!
Originally Posted by Oliver1234 View Post
Hi all,
So that's why i never saw any posts on here. Thanks for letting us know though!
I'm looking forward to seeing more of this when the time for it comes.
Discussion Starter · #228 ·
Originally Posted by nickbaldwin86 View Post
is it still being built?
Yes the computer is still being built, but sadly at the moment Oliver and I have been busy with school, college applications and other things so it will probably start again in the next 2 months or so.
Cool thanks for the update... good luck with school guys it is a very important step in life!
I'm on the same boat lol. I have a build but have not posted a build log, but some parts are sitting in my room.
Discussion Starter · #231 ·
Really? It gets tempting to start building cause i have mine in my tv room and so every time i come in there i just want to start building, but I know school work, sadly, comes above that.
Discussion Starter · #232 ·
Hi guys, it has been a while but things are starting to come back together. Oliver and I got back to the computer for the first time in 4 months to talk about the computer. The good news is we are starting to get more time and have an idea of what we have left to do. The bad news is that the updates will not be constant. But do not worry the updates will be more constant than once per 4 months.
Proof that I am not lying.
Discussion Starter · #234 ·
I have been thinking about converting my 250D into a mATX... I really want a mATX board so I can get another GTX980 into it
Nice, I remember that originally i was going to try and have sli/ corssfire in this build but I was a little worried about have enough rads to cool the whole thing if added. Plus I wanted to try and keep the exterior semi untouched, making it look as similar to the original case design as possible, but I'm sure you will figure it out.
Ya no room for water cool. I just plan to keep the system blowing hot air
I run the 980 ACX2.0 and it runs so chill that I am not really worried about heat... also my CPU is on a stock Intel cooler and never gets over 50c
Discussion Starter · #236 ·
I guess that works too, you don't have to be quite as fancy as me.
Discussion Starter · #238 ·
Right now, we haven't been thinking about it since school has once again overwheled us. As for when we will work on it, I honestly don't know exactly anytime before summer. Oliver is very busy these next couple of months and I lack the space to finish the project fully. I will be able to post updates but don't expect this to be finished before summer.
